This is a question following on from my previous one "How can I improve my testbench for testing a 1024x4 RAM memory in Verilog".
Basically, I have modified the previous solution in an attempt to test a 1024x4 RAM memory, which uses coincident decoding and was implemented using gate-level description.
I have modified the code to use a for loop to run through the coincidental addresses of the decoders, for both the write and read operations.
My test bench works with regards to the write operation and as long as the read portion of the code is commented out.
Please see code below:
module tb_RAM_1024x4();
wire  [3:0] Mem [0:1023];
wire  [3:0] DataOut;
reg   [3:0] DataIn;
reg   [4:0] X_Address,Y_Address;
reg   Enable, ReadWrite;
RAM_1024x4    M0 (DataOut, DataIn, X_Address, Y_Address, Enable, ReadWrite);
  initial begin
  Enable = 0;
  DataIn = 4'b0000;
  #10 ReadWrite = 0;
  end
  // Write random data to specific addresses
  initial #28830 $finish;
  integer  i, j;
  initial begin
     for(i = 0; i < 32; i = i + 1) begin
        #5 X_Address = i;
        for(j = 0; j < 32; j = j + 1) begin
           #5 Y_Address = j;
           write(X_Address, Y_Address, $random);
        end
     end
  end
//      initial begin
//      Enable = 0;
//      #20 ReadWrite = 1;
//      end
    // Read data from specific addresses
//      initial #28830 $finish;
//      initial begin
//         for(i = 0; i < 32; i = i + 1) begin
//           #5 X_Address = i;
//           for(j = 0; j < 32; j = j + 1) begin
//              #5 Y_Address = j;
//              read(X_Address, Y_Address);
//           end
//         end
//      end
 task write (input [4:0] addr1, [4:0] addr2,[3:0] din);
    begin
       #20 X_Address = addr1; Y_Address = addr2;
       #1 Enable = 0;
       #2 Enable = 1;
       DataIn = din;
    end
 endtask
 task read (input [4:0] addr1, [4:0] addr2);//, [3:0] dexpect);
    begin
       #1 Enable = 0;
       #2 Enable = 1;
     end
  endtask
endmodule
Also provided is the waveform for the write operation. When the read portion of the code is uncommented, it affects the operation of the write operation for some reason which i haven't quite figured out.
Therefore, any insight that anyone can provide will be very much appreciated.1024x4 RAM Waveform
Uncommenting your read code, your ReadWrite signal was 1 for all your read and write calls.
You could combine your loops to interleave the writes and reads, dynamically changing ReadWrite.
integer  i, j;
initial begin
    Enable = 0;
    DataIn = 4'b0000;
    ReadWrite = 0;
    X_Address = 0;
    Y_Address = 0;
        #5 X_Address = i;
            #5 Y_Address = j;
            ReadWrite = 0;
            #10;
            ReadWrite = 1;
        end
    end
end
You could simplify it by moving ReadWrite inside the tasks (like Enable).
  • \$\begingroup\$ Thanks for the insight. It has allowed me to arrive at the solution that I was looking for, which is to write and read data to and from the addresses sequentially. I have moved the Enable command and ReadWrite requests out of the task functions, which have been discarded with and this has reduced the simulation time by approx. 80%. \$\endgroup\$
    – aLoHa
    Sep 3, 2020 at 12:33
A possible solution for a testbench that tests the write and read operation to the addresses within a 1024x4 RAM memory sequentially would be the following:
  wire    [3:0] DataOut;
  reg     [3:0] DataIn;
  initial #11600 $finish;
  integer  i, j;
  initial begin
        #5 X_Address = i;
        Enable = 0;
           #5 Y_Address = j;
           #1 DataIn = $random;
           Enable = 1; ReadWrite = 0;
        end
     end
        #5 X_Address = i;
        Enable = 0;
           #5 Y_Address = j;
           Enable = 1; ReadWrite = 1;
        end
     end
  end
endmodule
1024x4 RAM Memory Waveform
