Let us say I have a DAC that gives out differential signal and I want to amplify it. How can I do that?
  • \$\begingroup\$ With 673 points, one should now how to ask questions here. Inserting your title into google results in the differential amplifier and instrumentation amplifier as possibilities. \$\endgroup\$
    – Swedgin
    Sep 1, 2020 at 7:16
  • \$\begingroup\$ THS4521 and similar. Actually... do you need single-ended or differential output? \$\endgroup\$
    – frr
    Sep 1, 2020 at 7:26
    \$\begingroup\$ How can I do that? You would use a differential amplifier, learn about those by putting that term into Google search and doing some studying. \$\endgroup\$ Sep 1, 2020 at 8:13
  • \$\begingroup\$ What kind of output the amplifier should have? Single-ended or differential? Do you want a fully differential amplifier? What is the required bandwidth and dynamic range of the signal? \$\endgroup\$
    – Justme
    Sep 1, 2020 at 9:01
You can do this with a differential amplifire or a differential transformer. Take a look at pg.4/pg.5 of this document.
