I am a 14 year old electronics noob. I am mostly a programmer and mechanical designer. I have been working on a robot which needs around 4 amps of current. I am thinking about using a simple 5V 4A AC to DC adapter but they seem to be a pain to connect to a PCB. Especially since many mounts cannot even work with 4 Amps. I am trying to power 4 micro servos.
EDIT: How can I power this?
Edit 2: here is an image of my planned circuit:
Circuit Diagram
Edit 3: There is a slight error in the circuit diagram in servo 2: pin 2 of that is supposed to be connected to pin 6 of the Arduino.
    \$\begingroup\$ Do you have a question or did you mistake this site for your diary? \$\endgroup\$
    Commented Sep 1, 2020 at 18:20
  • \$\begingroup\$ oh shoot sorry! \$\endgroup\$
    – TheRealJoe
    Commented Sep 1, 2020 at 18:21
there are plenty of options...
don't know what your best dealer or online shop is, but for a PCBs things like that work perfectly:
https://www.reichelt.de/stecker-buchsen-c7538.html?&nbc=1
https://www.reichelt.de/leiterplattenklemmen-c7541.html?&nbc=1
you get em in all sizes, for all currents. Just search / ask for some good shops in your area of the world.
Maybe you even want such gernan called "Federzugklemme" (spring-type terminal) where the contact is achived with a stong metal spring. they have perfect contact. skrewed terminal might get loose by vibration. spring-type terminal are the better choice in that case
https://www.reichelt.de/federkraftklemme-steckbar-2-pol-rm-5-00-sp-02-5-vbpc-p159608.html?&trstct=pol_8&nbc=1
https://www.reichelt.de/federkraftklemme-3-pol-0-08-0-5-mm-rm-2-5-ast-021-03-p72167.html?&trstct=pol_12&nbc=1
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$
    – Voltage Spike
    Commented Sep 1, 2020 at 23:14
If there's a way to split up your servo supplies, you could get away with two 5V/2A supplies, like for example fast-charge USB wall warts. That might be more compact than a typical off-the-shelf open-frame supply.
  • \$\begingroup\$ Thanks! That just might work as I have plenty of those. I have also been thinking I might only need 5v2a since I will never be stalling all servos (or even using) at once. \$\endgroup\$
    – TheRealJoe
    Commented Sep 1, 2020 at 18:46
