I would like to jump to 4 layers pcbs, but everytime that I've looking in Google information, it's much complex than 2 layers. Impedance tracks, resistance of the tracks, decoupling capacitors for some impedance, EMIS, and the stack of course. I know this concepts separately, but when I'm designing I don't really know much more than the datasheet can tell me.
I'm hesitant to answer this because I'm also inexperienced, but in my limited design experience 4 layer design is less complex than 2 layer because you have a dedicated ground and power plane. Conversely, when trying to make a 2 layer board work, you need to put a lot of care into minimizing the loop area of your power and ground traces as you route them through the signal layers. Dave Jones did a whole series of EEVBlog episodes about this:
https://www.youtube.com/watch?v=crs_QLuUTyQ
I think probably what you mean is that when you look at things designed with 4 layer boards they're generally more complex projects, which makes sense of course. But going to 4 layers doesn't mean you have to start worrying about controlled impedance or decoupling whereas you could ignore them otherwise. That depends on your project, and you'd need the same things on a 2 layer design, possibly more so in the case of decoupling.
I want to put a capacitor for decoupling some signal in a four layer PCB, but I want to know how it's affecting to my circuit and why I'm placing it in this place.
Related episode on decoupling: https://www.youtube.com/watch?v=1xicZF9glH0
But in general you place them in the same place on a two or a four layer board: as close as possible to the thing you are decoupling and in a way that minimizes the current loop area. Usually this is much easier on a 4 layer board since you aren't cutting up your power and ground with lots of signal traces.
I want to know the design guidelines for this kind of things and the ecuations,etc... I mean, i want to order my pcb and know that it is going to work well with efficency.
Since the cost of 4 layer board prototyping has fallen down to almost the same as 2 layer, I would certainly use a 4 layer board here. It will make everything easier and make your errors less likely to be fatal to your circuit's functioning. I don't think there is any substitute for experience though, so you're probably going to end up with a bad design for your first project. But you have to learn somehow.
