With respect to how to reduce the effect of ground currents on sensitive analog portions of a circuit, Art of Electronics (3rd Edition) chapter 8 includes this suggestion:
My question: what is the purpose and effect of the 10 ohm resistor connecting the two grounds?
I understand how this allows the low-level section's ground to float a little separately from the high-level ground, which might come about if the two sections were each attached to different external systems (not shown in the diagram), each with their own disparate grounds, while still allowing the high and low level sections to receive power from the same PSU.
However usually the low-level section will need to communicate signals to the high level section (or vice versa), and, for those signals, any current in the 10 ohm ground resistor produces a voltage that adds unwantedly to the analog signals between the two sections. After all, this excerpt follows a discussion of reducing the impedance of ground networks (along with deliberately designing the current paths) for just that reason, not increasing them.
For example, the 10 ohm resistors in the positive and negative rails will split the voltage drop attributable to the current consumption of the low-level section, thereby adding that half amount to any signals from one section to the other. That's already an issue, and made worse if that current consumption fluctuates (more of a problem at low frequency, since higher frequencies are absorbed by the reservoir capacitor.)
No doubt there are techniques that ameliorate the mentioned problem, such as communication between the two sections using an analog optocoupler or differential signals. But for plain old individual analog signals, I'm at a loss to understand how that 10-ohm ground resistor helps, or in what scenarios, compared to a zero resistance connection.
Thoughts?
  • \$\begingroup\$ Not the complete solution, but I think this circuit is relying on power supply margin. If the lowside amp is only going to swing to +5V and you have a +10V rail, then you can afford to lose some of it in the 10Ω resistor, but I would probably choose a ferrite bead. \$\endgroup\$ – Aaron Sep 4 '20 at 23:04
  • \$\begingroup\$ I once had an RF FAE suggest using a 1kΩ on the power supply pin to their low power cmos antenna switch. Why? For noise decoupling. It worked like a charm. \$\endgroup\$ – Aaron Sep 4 '20 at 23:07
  • \$\begingroup\$ @Aaron yes -- agreed. However my question is specifically about the 10-ohm resistor on the ground side. \$\endgroup\$ – gwideman Sep 4 '20 at 23:34
  • \$\begingroup\$ @gwideman Look at what's between the high-level supply and the low-level supply sides. Two resistors, both sides of the rails, with a bypass cap on the low-level supply side. What's difficult to follow about that? (And yes, you'd want both Rs. Think about it. And while doing so, please note that the low-level input shows two inputs -- so its differential mode.) Good question though. +1. (In past, I've used as much as a 5-pole isolation, high and low side, using beads and caps and resistors to isolate a low-level input with very high gain, guard rings, metal can, etc.) Others have done more. \$\endgroup\$ – jonk Sep 5 '20 at 1:31
  • \$\begingroup\$ @jonk OK, so what is the actual function of the 10 ohm resistor in the ground path, or even more, your multi-pole filter between the two grounds. At best it causes the two grounds to differ due to the DC and AC current consumption of the low-level section. At most it causes the grounds to further vary due to some external connections to the two sections. And sure, differential input is suggested by the two inputs to the low level side. So the single input to the high-level side suggests singled ended signals from low level to high level? Making the ground offset a problem. \$\endgroup\$ – gwideman Sep 5 '20 at 20:45
A lock-in amplifier accept extremely small input signals, often below thermal noise levels. Groundloop currents can be a dominant noise source.
A low-noise JFET preamplifier and its BNC front panel input jack are isolated from ground with a small resistor of about 10 ohms. Ground-loop currents on input coax cables must flow through this 10-ohm resistor. The resistance is far larger than coax shield (braid) resistance.
Ground currents develop a voltage across the 10 ohm resistor, while those same ground currents develop a much smaller voltage along the coax braid. The preamp rejects the voltage across the 10-ohm resistor, but must cope with the much smaller voltage drop along coax braid.
A differential amplifier rather than a single-ended JFET preamp could also be used, where the voltage difference between hot input and BNC ungrounded shell is amplified. But a differential amplifier is likely noisier than a discrete single JFET.
  • \$\begingroup\$ The AofE 3rd edition diagram shows a differential mode amplifier on the low-level side. \$\endgroup\$ – jonk Sep 5 '20 at 1:26
  • \$\begingroup\$ @DAS I added that gnd as an afterthought, because we're talking about ground loop currents. Without it, there's no loop. \$\endgroup\$ – glen_geek Sep 5 '20 at 12:49
  • \$\begingroup\$ Your example is about coupling two separate systems together, where I guess we assume that the two triangle ground symbols are at the same potential (due to a not-shown connection), but somehow a voltage is induced in the the ground braid, perhaps inductively or capacitively from some other influence? Your R1 10-ohm resistor is not in the ground path. You've essentially created a JFET differential input stage where the two inputs are the gate and the source, and R1 is the source resistor. I do see how this solves a problem, but I don't think it's quite the case I'm asking about. \$\endgroup\$ – gwideman Sep 5 '20 at 20:52
  • \$\begingroup\$ Yes, triangle symbols connect, likely via power-line ground...many signal sources are unavoidably grounded (if the source floats above gnd, we have no problem with ground loops). Reducing gnd path resistance only increases groundloop currents due to magnetic coupling. And adding another ground adds loop area. That 10 ohm resistor decreases groundloop current because it is in series with the loop. I believe it is exactly the scenario in AofE. Noise at amplifier input not amplified doesn't appear at amplifier output. One should take care that no other currents flow through than 10ohm. \$\endgroup\$ – glen_geek Sep 5 '20 at 22:13
  • \$\begingroup\$ @glen_geek I appreciate your efforts, but thiis seems off-track from the AoE example, that's about a single system within a board or chassis, given that power is supplied to the low-level system via an R-C from a shared power supply. "That 10 ohm resistor decreases ground loop current". If you mean the AoE example, it may reduce GL current (from some unspecified source), but it won't cut down the corresponding offset voltage, which will add to analog signals crossing from low-level to high-level. (If you meant your R1, then as previously noted, you've essentially made a differential input). \$\endgroup\$ – gwideman Sep 5 '20 at 23:57
