EDIT: I realize that the original circuit is deeply flawed and will burn up upon re-entry. Thanks to anyone who can help me understand why!
I'm learning to analyze Class AB amplifiers, but haven't found a good source with information on how to determine their input impedance. I built this circuit as an example. It's a simple Class AB amplifier with resistors to overcome crossover distortion. I would love feedback on whether my understanding of \$R_{in}\$ is correct. I assumed both transistors have a \$\beta=50\$.
As far as I can tell, \$V_S\$ will see two branches: first, it will see the \$60\Omega\$ R2 in series with the parallel combination of R1 and the impedance looking into the base of Q1; in the other branch, it sees \$60\Omega\$ from R3 in series with the parallel combination of R4 and the base of Q2. So an equation like the following should work, yes?
$$R_{in}=(R_2+(R_1||R_{ibQ1}))||(R_3+R_4 || (R_{ibQ2}))$$
I started with the Q1 branch. First I found \$r_e\$. \$I_C\$ fluctuates between 2.6mA and 2.7mA, giving a very small value for \$r_e=25mv/2.6mA=9.62\Omega\$. With this in mind I can solve for \$R_{ibQ1}=\beta*(r_e+R_L)=50*(1000+9.62)=50,481\Omega\$. \$R_{ibQ1}\$ is in parallel with R1 and that combination is in series with R2, so the entire Q1 branch of the circuit is $$R_{Q1branch}=60\Omega+(1000\Omega||50481\Omega)=1040\Omega$$
From here I'd like to think it's as easy as imagining the Q2 half of the circuit as equivalent in impedance. The total input impedance of the circuit, then, is half of the previous calculation, or \$R_{in}=1040||1040\Omega = 520\Omega\$
I'm sure this isn't exactly correct, as it seems way too simple to only solve half the circuit. I'd love to hear all the ways I've been led astray. Please note that this is not an amplifier I imagine has any real purpose, just one that works enough to help me understand how to analyze its input impedance.
  • \$\begingroup\$ This is not a rational circuit as it will burn up in less than a minute, assuming power supply can supply the loads of amps. \$\endgroup\$
    – user105652
    Sep 6, 2020 at 2:14
  • \$\begingroup\$ So, obviously there is something about this circuit I don't understand! I modeled it after this example: electronics-tutorials.ws/amplifier/class-ab-amplifier.html About a third of the way down is a section called "Class AB Amplifier Resistor Biasing." I'm confused and don't get why mine would burn up so badly, but now that two people have told me it will inside of 15 minutes I believe you both. \$\endgroup\$
    – nuggethead
    Sep 6, 2020 at 2:21
  • \$\begingroup\$ @nuggethead There are a lot of people who just want to get a vague idea of how things work. And there are some who are willing to dumb it down -- using a behavioral circuit that no one would ever seriously consider building except perhaps as a laboratory exercise, at most. It's there to get some basic ideas across without getting bogged down into details that would get in the way of making the main point. Their readers will learn some new ideas worth grasping at. There should be a warning on that page: "Don't build anything you see on this page without a fire extinguisher." \$\endgroup\$
    – jonk
    Sep 6, 2020 at 3:26
  • \$\begingroup\$ @nuggethead Are you interested in how to actually design something that might work? Or just interested in getting us to do what that web page you've been reading can't do because it is totally inanimate -- namely, respond to your questions? If the latter, I'm not interested. \$\endgroup\$
    – jonk
    Sep 6, 2020 at 3:56
  • \$\begingroup\$ @jonk, thanks for writing. It seems that the page I was working from was dumned down. Also, I used a split supply like they did on their first example, but the one with four resistors was a single supply. So, that might explain at least a bit of my confusion. I appreciated the fire extinguisher comment, for what it's worth. To your second comment, I'd answer "both.". I'm interested in learning how to actually design useful circuits, and also wising I could ask the websites I do find questions to help me understand. As I said first, I can't find a good source to look at. Any ideas? \$\endgroup\$
    – nuggethead
    Sep 6, 2020 at 20:41
At midpoint, your transistors will be conducting AMPS and AMPS, because of the 1.2 volts across each base. And depending accuracy of the transistor model and if a power_transistor model, the current could be thousands or millions of amps, which melts the copper wires in your circuit.
These AMPS will flow thru BOTH transistors, dissipating hundreds of watts.
Or even millions of watts.
And the BETA likely will be very low, because BETA does collapse at high current densities.
I doubt that is what you intended.
Impose a zero volt input. We'd like approx. zero volts output, and some moderate milliamp emitter current.
For easy back_of_envelop analysis, remove the bottom half of the circuit. Now we have two resistors and a NPN. Ground the emitter of the NPN. What are the currents?
We'd like the 2 resistors (1Kohm and 60 ohms) to be a well-behaved voltage divider. So temporarily remove the NPN.
The 1Kohm dominates, thus the current (viewing that 1 Kohm resistor as a nice 1mA/volt beast) from the 20 volts (ignore the 60 ohms) is 20 milliAmps, closely. Not exactly . But this is back_of_envelope.
Now reinstall the 60 ohms. 1mA produces 60mV. 10mA produces 600mV (about what we need). And 20mA produces 1,200 milliVolts. Which is what we get. So?
If we assume 0.6 volts for 1milliAmp for many bipolars (approximately), then 1.2 volts will produce
  • scale_factor = 10^ (1.2 - 0.6)/0.058
  • scale_factor = 10 ^10
and the collector current (very close to the emitter value) will be
  • 1mA * 10^1 = 10^7 amps or 10,000,000 amps
To avoid that, let us eat up that extra 0.6 volts, by inserting a 3 ohm resistor between each emitter and the Vout. The approximate current will be 0.6v / 3 = 0.2 amps, much more controlled than that 10,000,000 amps.
And if your simulator has a Power Bipolar Transistor model, then you will see about 0.2 amps (maybe 0.05 or 0.5) but not 10,000,000 anps.
Inserting small value resistors in emitter-to-output-node is a standard method for class AB amplifiers.
to nuggethead
the "scalefactor" in this case is just the name I attached to the RATIO of current at 0.6 volts across the emitter_base to the current at `1.2 volts across the emitter_base.
  • \$\begingroup\$ Ha! No, I was not intending that to say the least. I'm not sure I understand, though. Can you please explain what would cause this? My simulation shows everything is happy... \$\endgroup\$
    – nuggethead
    Sep 6, 2020 at 1:58
  • \$\begingroup\$ @nuggethead Show us the plot of your simulated emitter currents (both driver BJTs, please) through perhaps 5 cycles' worth of time, along with a curve for the load resistor current. \$\endgroup\$
    – jonk
    Sep 6, 2020 at 3:20
  • \$\begingroup\$ @analogsystemsrf I've never heard of scale_factor could you point me towards where I can learn more about that? I'll try the simulations you suggested this evening. Thank you sincerely for your help! \$\endgroup\$
    – nuggethead
    Sep 6, 2020 at 20:44
