I got a Hikvision camera DS-2CD2332-I that was mistakenly connected to 48 V power supply instead of 12 V. I checked the board and found a TVS diode is getting hot. The power supply LED was blinking at some regular interval while connected.
I removed the diode, connected the camera and surprisingly it worked! So I guess, before using it for surveillance, I need to get new part instead of fried one, so another V spike doesn't kill the board.
I have a problem identifying that diode. All I could find is manufacturer is BrightKing, but can't get any specs about power/voltage... Markings are P450 DEM
Any hint? What would be proper replacement?
Thanks
diode
From this data sheet, the DEM package marking code matches part number SMDJ15CA.
  • \$\begingroup\$ Thanks crj11, I'll check this. \$\endgroup\$ Sep 6, 2020 at 16:05
