I have a Verilog array defined as :
logic [ 0 : num_elements - 1 ] [ element_width - 1 ] some_array ;
I want to assign every array element with a vector that is all ones: "11...1". I tried this but I get an error:
some_array <= { num_elements { element_width { 1'b1 } } } ;
What's the correct syntax ?
To assign unpacked 2d array in SystemVerilog with a single line:
some_array <= '{ default: '1 };
Verilog cannot be done in a single line. It must use a for-loop:
for ( i = 0; i < num_elements; i = i +1)
  some_array[i] <= {element_width{1'b1}};
  • \$\begingroup\$ Suppose: num_elements = 4 element_width = 8 Making it more complicated I want each element to get "0xFA" So now - my ONLY option is to use the for-loop approach ? There's no way to do it in a single line like in VHDL ? some_array <= ( others => ( others => x"FA" ) ) ; \$\endgroup\$
    – shaiko
    Sep 7, 2020 at 9:02
    \$\begingroup\$ @shaiko the SystemVerilog '{default: } approach will still work. Refer to the SystemVerilog LRM \$\endgroup\$
    – Greg
    Sep 7, 2020 at 17:30
  • \$\begingroup\$ It'll work for packed as well as unpacked array ? \$\endgroup\$
    – shaiko
    Sep 7, 2020 at 17:45
Since some_array is all packed, you can do
some_array <= '1;
  • \$\begingroup\$ What if it was unpacked ? \$\endgroup\$
    – shaiko
    Sep 6, 2020 at 20:10
  • \$\begingroup\$ I'm looking for a syntax to assign each array element individually...similar to what I wrote in my example. \$\endgroup\$
    – shaiko
    Sep 6, 2020 at 20:34
    \$\begingroup\$ In your example, each element is a single bit. You might want to check out the default: clause of an array assignment pattern \$\endgroup\$
    – dave_59
    Sep 6, 2020 at 22:55
