I'm trying to detect a small AC signal (~10kHz) generated by a phototransistor on a magnitude of 10nA~1uA using the following circuit by converting the signal to voltage signal first and then filter it:
However, environmental light generates a constant offset of approximately 50uA, which is much greater than my signal. This means that if need to convert the current signal to voltage signal first before filtering, assuming I power the amplifier with a 5V voltage source, R needs to be smaller than 100K Ohm in order to prevent saturation of the amplifier. As a result, the voltage signal would be merely 1~100mV, which is too small for accurate detection due to noise issues. If the 50uA background could be filtered out, I can use a larger R to convert current signal to a larger voltage signal.
In theory, some form of high-pass filter should solve the problem, but I have no idea how to apply a high-pass filter that operates directly on the current signal.
Any hint would be much appreciated! thanks!
Note: phototransistor's collector should be fixed at 0V.
    \$\begingroup\$ Welcome to EE.SE! You write phototransistor but your schematic shows a photodiode. If you click on edit and the schematic symbol, a schematic editor will open. \$\endgroup\$
    – winny
    Sep 7, 2020 at 19:46
  • \$\begingroup\$ @winny Thanks for your kind reminder! I've edited my post, however, I cannot find phototransistors in the circuitlab. \$\endgroup\$
    – Wjx
    Sep 7, 2020 at 20:09
  • \$\begingroup\$ I may remember wrong, but can you set the base of an NPN to photo input? \$\endgroup\$
    – winny
    Sep 7, 2020 at 20:13
  • \$\begingroup\$ @winny my phototransistor only provides two pins, a collector, and an emitter. the base is tied internally to the cathode of a photodiode. \$\endgroup\$
    – Wjx
    Sep 8, 2020 at 6:50
  • \$\begingroup\$ Yes, that’s what I’m trying to help you show in CircuitLab :-) \$\endgroup\$
    – winny
    Sep 8, 2020 at 7:03
Inspired by @analogsystemsrf, I designed and verified a circuit which can serve this purpose well.
The key here is to design a stable, second order LPF on the feedback loop. Filters of 3+ orders would possibly cause oscillation so this is the best I could think of. Here current goes in from I_in pin, and the AC voltage goes out at V_out whild DC voltage can be obtained at V_FB.
Hopefully this could be useful for further viewers.
Sunlight can be removed, with a low_pass feedback.
  • Connect a series R + R network from output back to Vin-.
  • these new resistors are in parallel with your current_to_voltage Resistor
  • we need a very slow time constant, so add 1uF capacitor at midpoint of the 2 new series resistors
  • make both the new resistors of value 1MegOhm.
  • \$\begingroup\$ Hi! Thanks for your reply, I get your point but do you mean that the feedback part should be something like this? ---R---C---R--- in paralell with --------R--------- \$\endgroup\$
    – Wjx
    Sep 8, 2020 at 6:41
  • \$\begingroup\$ I suppose this is a high-pass filter instead? it has lower Z on higher frequency. But your point is helpful, I would check if there's any other way to use another amplifier to generate a LPF on the feedback loop. \$\endgroup\$
    – Wjx
    Sep 8, 2020 at 6:47
