I am wondering if my implementation of voltage sensitivity coefficients for unbalanced three-phase-four-wire radial distribution feeders is correct.
We got \$\bar{V}\$ for phase(s) of all the buses and \$\bar{Y}\$, the admittance matrix of the feeder. \$\mathcal{S}\$ is the set for phases of the slack bus, and \$\mathcal{N}\$ is the set for phase(s) of all the buses. For real and reactive power injections \$P\$, \$Q\$, all wye-connected,the following relationship can be obtained using first order Taylor expansion: $$ d |\bar{V}_{i}| = \sum_{j \in \mathcal{N}} \frac{\partial |\bar{V}_{i}|}{\partial P_j} \cdot d P_j + \sum_{j \in \mathcal{N}} \frac{\partial |\bar{V}_i|}{\partial Q_j} \cdot d Q_j \quad \forall i \in \mathcal{N} $$ where we should get \$\partial \bar{V}_{i} / \partial P_{j} \$ first, and then use: $$ \frac{\partial\left|\bar{V}_{i}\right|}{\partial P_{l}}=\frac{1}{\left|\bar{V}_{i}\right|} \operatorname{Re}\left(\underline{V}_{i} \frac{\partial \bar{V}_{i}}{\partial P_{l}}\right) $$
The calculation for \$\partial \bar{V}_{i} / \partial Q_j\$ is similar.
In [christakou2013efficient], to calculate \$\partial V_{i} / \partial P_j\$, \$(\forall i, j \in \mathcal{N} \cap \mathcal{S}) \$, we need to solve the following set of linear equations: $$ \begin{aligned} \frac{\partial \bar{V}_{i}}{\partial P_{k}} &= 0 \quad \forall i \in \mathcal{S}, \forall k \in \mathcal{S} \cup \mathcal{N} \\ \frac{\partial \underline{V}_{i}}{\partial P_{k}} &= 0 \quad \forall i \in \mathcal{S}, \forall k \in \mathcal{S} \cup \mathcal{N} \\ \frac{\partial \bar{V}_{i}}{\partial P_{k}} &= 0 \quad \forall i \in \mathcal{N}, \forall k \in \mathcal{S} \\ \frac{\partial \underline{V}_{i}}{\partial P_{k}} &= 0 \quad \forall i \in \mathcal{N}, \forall k \in \mathcal{S} \\ \frac{\partial \underline{V}_{i}}{\partial P_{i}} \sum_{j \in \mathcal{S} \cup \mathcal{N}} \mathrm{Re}(\bar{Y}_{i j} \bar{V}_j) + \mathrm{Im}(\underline{V}_i) \sum_{j \in \mathcal{N}} \mathrm{Im}(\bar{Y}_{i j}) \frac{\partial \bar{V}_{j}}{\partial P_i} + \mathrm{Re}(\underline{V}_i) \sum_{j \in \mathcal{N}} \mathrm{Re}(\bar{Y}_{i j}) \frac{\partial \bar{V}_{j}}{\partial P_i} &= 1 \quad \forall i \in \mathcal{N} \\ \frac{\partial \underline{V}_{i}}{\partial P_{i}} \sum_{j \in \mathcal{S} \cup \mathcal{N}} \mathrm{Im}(\bar{Y}_{i j} \bar{V}_j) + \mathrm{Im}(\underline{V}_i) \sum_{j \in \mathcal{N}} \mathrm{Re}(\bar{Y}_{i j}) \frac{\partial \bar{V}_{j}}{\partial P_i} + \mathrm{Re}(\underline{V}_i) \sum_{j \in \mathcal{N}} \mathrm{Im}(\bar{Y}_{i j}) \frac{\partial \bar{V}_{j}}{\partial P_i} &= 0 \quad \forall i \in \mathcal{N} \\ \frac{\partial \underline{V}_{i}}{\partial P_k} \sum_{j \in \mathcal{S} \cup \mathcal{N}} \mathrm{Re}(\bar{Y}_{i j} \bar{V}_j) + \mathrm{Im}(\underline{V}_i) \sum_{j \in \mathcal{N}} \mathrm{Im}(\bar{Y}_{i j}) \frac{\partial \bar{V}_{j}}{\partial P_k} + \mathrm{Re}(\underline{V}_i) \sum_{j \in \mathcal{N}} \mathrm{Re}(\bar{Y}_{i j}) \frac{\partial \bar{V}_{j}}{\partial P_k} &= 0 \quad \forall i, k \in \mathcal{N}, k \neq i \\ \frac{\partial \underline{V}_{i}}{\partial P_k} \sum_{j \in \mathcal{S} \cup \mathcal{N}} \mathrm{Im}(\bar{Y}_{i j} \bar{V}_j) + \mathrm{Im}(\underline{V}_i) \sum_{j \in \mathcal{N}} \mathrm{Re}(\bar{Y}_{i j}) \frac{\partial \bar{V}_{j}}{\partial P_k} + \mathrm{Re}(\underline{V}_i) \sum_{j \in \mathcal{N}} \mathrm{Im}(\bar{Y}_{i j}) \frac{\partial \bar{V}_{j}}{\partial P_k} &= 0 \quad \forall i, k \in \mathcal{N}, k \neq i \end{aligned} $$ where \$\underline{V}\$ is the conjugate of \$\bar{V}\$. I am not sure about this equation set, because it is written in a simplified version in the paper. In [christakou2013efficient], there are only two equations: $$ \begin{align} \frac{\partial \bar{V}_{i}}{\partial P_{l}} &= 0, \quad \forall i \in \mathcal{S} \\ \frac{\partial \underline{V}_{i}}{\partial P_{l}} \sum_{j \in \mathcal{S} \cup \mathcal{N}} \bar{Y}_{i j} \bar{V}_{j}+\underline{V}_{i} \sum_{j \in \mathcal{N}} \bar{Y}_{i j} \frac{\partial \bar{V}_{j}}{\partial P_{l}} &= \mathbb{1}_{\{i=l\}} \end{align} $$
Besides, I am wondering if there are other methods. I read some method using impedance matrix, but I don't want delta-connected loads in [maharjan2020enhanced]. I know we cannot have inverted Jacobian matrix because Newton-Raphson algorithm should not be used. I don't want to use perturb-and-observe method, for example in [tamp2014sensitivity].
- Christakou, K., LeBoudec, J. Y., Paolone, M., & Tomozei, D. C. (2013). Efficient computation of sensitivity coefficients of node voltages and line currents in unbalanced radial electrical distribution networks. IEEE Transactions on Smart Grid, 4(2), 741-750.
- Maharjan, S., Khambadkone, A. M., & Peng, J. C. H. (2020). Enhanced Z-bus method for analytical computation of voltage sensitivities in distribution networks. IET Generation, Transmission & Distribution, 14(16), 3187-3197.
- Tamp, F., & Ciufo, P. (2014). A sensitivity analysis toolkit for the simplification of MV distribution network voltage management. IEEE Transactions on Smart Grid, 5(2), 559-568.
