I know you can smooth DC with a capacitor but what if you have an unstable mains AC voltage (here in the UK that's 240V 50Hz)? Are there components that can be used or products one can make/buy for the same sort of end goal, a more constant supply?
    \$\begingroup\$ You need an AC-DC-AC converter \$\endgroup\$
    – JonRB
    Sep 8 '20 at 22:29
  • 5
    \$\begingroup\$ There are a number of options (including motor-generators, AC/DC/AC converter, Constant voltage transformer...). You should edit your question to say what type of AC power you have (e.g. 1 phase 50Hz 230V?), what is wrong with your AC (Transients? Brownouts? short dropouts? Varying voltage? Varying frequency?) and what you need to provide power to (Motor? Resistive load? SMPS?). \$\endgroup\$
    – Jack B
    Sep 8 '20 at 22:43
  • \$\begingroup\$ Why do you want a 'constant' AC supply? \$\endgroup\$
    – Chu
    Sep 9 '20 at 0:52
  • \$\begingroup\$ If you truly need one, buy. Don't build because this is on the high-end of power projects. \$\endgroup\$
    – DKNguyen
    Sep 9 '20 at 1:19
    \$\begingroup\$ Higher-end UPS (Uninterruptible Power Supplies) have this function. It's called a Double Conversion On-Line UPS. \$\endgroup\$
    – StarCat
    Sep 9 '20 at 9:47
You could try a mains surge suppressor. They are cheap and might work if the problem is excess spikes on the mains. Do the LED lights flicker if driven from a wall circuit rather than lighting circuit? If so, try the suppressor. If not, then it is something else
