I have a few questions about what this code does and how it works:
x <= '{default:'1} ;
  1. What is the purpose of the "default" keyword ?
  2. What is the purpose of the inner single quote apostrophe before the 1 in this case ?
  3. What is the purpose of the inner single quote apostrophe before the { in this case ?
    \$\begingroup\$ Stackoverflow has a question on this. \$\endgroup\$
    – user103380
    Sep 9, 2020 at 19:59
    \$\begingroup\$ I've read the question on Stackoverflow before posting this one. I'm not asking the same thing. \$\endgroup\$
    – shaiko
    Sep 9, 2020 at 22:40
The inner single quote before the 1 is a numeric literal fill. The '0, '1, 'z, and 'x literals will be extended to fill the width of whatever context they are used in.
The outer single quote before the { means that this is an assignment pattern to an array or struct. Assignment patterns require a value for every element of the array or struct, which can be positionally ordered or matched by name/index. When matched by name/index, the default: serves as a match to any unspecified element.
This is all explained in section 10.9 Assignment patterns in the IEEE 1800-2017 SystemVerilog LRM
  • \$\begingroup\$ In fact your answer states the same as mine, except you use more formal terms. But it's in no way more correct. \$\endgroup\$
    – schnedan
    Sep 10, 2020 at 7:14
As far as I know:
  • its SystemVerilog
  • '{} defines a (unnamed) struct
  • default:'1 , as the default width is 32bit, is 32x '1' as constant
(if not correct, please correct me)
