A signal is defined as :
logic [width_x-1:0] x;
I want to assign x a value where the second bit from the top is '1' and all other bits are '0'. For example, if width_x is 4 then I want x to be "0100". In VHDL, it can be done as follows:
x<=(x'length-1=>'1',others=>'0');
What will be the closest Verilog/SV equivalent ?
    \$\begingroup\$ the VHDL one won't do precisely what you're asking either, unless the LSB is numbered 1 (not 0). You probably meant x'left-1=>'1' \$\endgroup\$ Sep 10 '20 at 16:09
Here's another method:
x <= {2'b01, {width_x-2{1'b0}}};
Or you can use bit shifting if width_x is relatively small:
x <= 1 << (width_x - 2);
Basically you need these 2 lines:
x = 0; // to set all bits to 0
x[width_x - 2] = 1'b1; // to set 2nd topmost bit to 1
Below is more complete code.
module aa;
    parameter width_x = 14;
    initial begin
        $display("x = %b", x);
        #10 x = 0;
        #10 x[width_x - 2] = 1'b1;
        $finish;
    end
    endmodule
