I am trying to replicate the behaviour of this library: https://playground.arduino.cc/Main/CapacitiveSensor/ with an STM8, but I am not able to do it. I want to detect the proximity of the human hand from about 10 cm. I don't have sensibility, i can only detect a strong pression on the capacitive sensor (aluminium foil) and even the heartbeat, but no the proximity. With this library I had a perfect beahiour. I am using a 1 Mohm resistor.
This is a piece of code:
    disableInterrupts()
GPIOD->ODR &= 0b11111101; // sendPIN D1 to LOW
GPIOE->DDR &= 0b11111011; // receivePIN E2 to INPUT (=0)
GPIOE->DDR |= 0b00000100; // receivePIN E2 to OUTPUT (=1)
GPIOE->ODR &= 0b11111011; // receivePIN E2 to LOW
// delayMicroseconds(10)
enableInterrupts();
for ( t = 0; t < 1000; t++);
disableInterrupts()
GPIOD->ODR |= 0b00000010; // sendPin High
enableInterrupts();
//getADCValue();
In = (GPIOE->IDR & GPIO_Pin_2);
while (In == 0) {
    total++;
//stopTime = TIM3->CNTRH;
disableInterrupts();
GPIOE->ODR |= 0b00000100; // receivePIN E2 to HIGH
enableInterrupts();
for ( t = 0; t < 100; t++);
while (In != 0) {
    total++;
In the image you can see the two pins, and you can see the blue one cannot reach the 3.3 V treshold, and it does not change much with aluminium foil touch.
Is there a better way to build a proximity sensor?
Thank you
EDIT 1: This is my circuit, extremely simple:
enter image description here Instead of clamp is attached the aluminium foil. I did use the 1x probe.
EDIT 2: Ok, the probe was acting as voltage divider as you say. I also the function Delay that is connected to TIM4 in the STM8 I am using, event if I don't think it was actually a problem. I removed the probe and it works better. Actually the program works, but I can't have a good sensing range (looks to be 4-5 cms). Is there any way to increase the sensitivity? I tried reading the ADC after a defined and certain time, but it looks to have the same sensibility. Maybe it is the maximum? I Arduino and CapacitiveSensor I had a very long range (something like 20 cms)
  • \$\begingroup\$ Show your circuit and explain how you got your data. Some sort of USB scope? What is your scope's impedance? Did you use a 10x probe? Something like a 1 Meg probe impedance could easily form a voltage divider with a weak current source used for such a thing. \$\endgroup\$ – Chris Stratton Sep 10 '20 at 23:53
  • \$\begingroup\$ It is likely that your busy-delay loops are screwing up everything. Use hardware timers instead. \$\endgroup\$ – Lundin Sep 11 '20 at 7:35
  • \$\begingroup\$ @Lundin why do you think that? \$\endgroup\$ – max_s Sep 11 '20 at 10:02
  • \$\begingroup\$ @ChrisStratton I used PicoScope 2204A with 1x probe. I added the circuit to the post. \$\endgroup\$ – max_s Sep 11 '20 at 10:08
  • \$\begingroup\$ @max_s Because input may happen at any time and not just when it is convenient for your program to read it. \$\endgroup\$ – Lundin Sep 11 '20 at 10:09
The 1 megaohm source resistor and comparable input impedance of your scope with a 1x probe form a voltage divider preventing the test signal from reaching more than about half value.
Remove the scope probe - this circuit is too sensitive. If you must try to probe use a 10x probe, but it would be better that you have nothing extraneous connected to the test node at all.
