application -
10 nodes 1 meter apart
120 Ohm terminating resistors at last node and 1st node
i hope to use ADM2486
data rate 10-17Mbps
vdd1 5V and isolated vdd2 5V
what is the max current consumption on vdd2 side is it 58mA at 20Mbps?
Yes you are right. Thats what the datasheet states: 58mA at 20Mbps.
You may be interested, I think it was LT (linear technology), today part of analog devices, used to offer (>10 years ago) a part which integrates a RS485 transceiver + a dc/dc switchmode converter... so you only need a small transformer and you have a fully isolated solution with 1 IC. Maybe Ti is offering something similar.
Last maybe: Maybe you find these products with searching the keyword profibus, a very common RS485 based industrial bus.
small correction:
https://www.analog.com/media/en/news-marketing-collateral/solutions-bulletins-brochures/5745225673953RS_485_2006_c.pdf
here you find what I mentioned, but it's a 2 IC solution... you also need a small LDO.
  • \$\begingroup\$ ISOW1412 \$\endgroup\$
    – CL.
    Sep 12, 2020 at 19:08
