I want to communicate simple requests and ids over ultrasound.
To do this I need to modulate a message onto a 40kHz carrier to drive a ultrasound transducer.
Here you can find a simulation of what I am trying with a gilbert cell for modulation a difference amplifier as a driver for the transducer (not shown in the simulation) and an OOK demodulator consisting of a LP, an average detector and a comparator.
- Is the difference amplifier (with +-50V as supply) sufficient as a driver for the transducer and can I also use it for the other end to amplify the received signal ?
- If it is sufficient which HiV op amp would you recommend ?
- Do you see any other design flaws ?
