I study computer engeering notes for a cache memory and I try to understand what determines the length of the index and the tag fields. The first examples is for 64 bits and the second example is for 128 bits and I wonder if the tag field length is just chose arbitrarily or what is the reason for being 28 in the first case and 29 in the second case. In the first case the block size is 8 bytes and in the second case the block size is 16 bytes.
Why is the tag field length only 28 bits in the second case?
Source: http://www.ict.kth.se/courses/IS1500/2012/forel/2012-ce_f8ht.pdf
