hello every one for a project i need to work with a line sensor TCD1304 AP .
here it's the data sheet link http://www.spectronicdevices.com/pdf/TCD1304AP.pdf
i don't know what's the exactly protocol of this sensor
how i should use this ? what kind of processor i should use ? will a esp 32 work with this sensor ?
    \$\begingroup\$ have you read the datasheet? ... which parts do you understand? ... which parts do you not understand? \$\endgroup\$ – jsotola Sep 12 at 19:51
    \$\begingroup\$ I used to work with silicon that was specifically designed to interface with line sensors. The ESP8266 ADC isn't fast enough for this part, even if you could generate the timing. You need at least a 500 KHz sample rate. \$\endgroup\$ – cmm Sep 13 at 1:46
  • \$\begingroup\$ @cmm what's sample rate mean ? how i can determine sample rate of processor? could you introduce me a suitable processor for me ? \$\endgroup\$ – hossein Sep 13 at 5:57
  • \$\begingroup\$ @jsotola for example i understand NC pin , SS it's GND , VAD for analog out put ... am i right ? \$\endgroup\$ – hossein Sep 13 at 6:38
  • \$\begingroup\$ @jsotola then i don't know how work with ICG , SH , OS and Master Clock pins ... \$\endgroup\$ – hossein Sep 13 at 6:46
