I am trying to study the significance of resister divider feedback circuit in buck regulator.
This is the TI document I am referring to.
As per TI doc, voltage at the feedback pin is as follows,
When I try to estimate the same feedback voltage, I feel the drop at the R1 resistor (value in the red box) should be omitted from the equation. What is the information I am missing here.
The Thevenin equivalent resistance at the feedback node is Req = R1||R2 = R1*R2/(R1+R2), so the current into the FB node has an influence Ifb*Req.
So the equation is correct. For low values of R1 & R2 the effect of Ifb will be small, but it will be there.
The situation looks like this:
And to find \$V_{FB}\$ voltage we can use a superposition theorem.
First, we remove the current source (\$I_{FB}\$) thus we have:
$$V_1 = I*R_2$$ $$I = \frac{V_{DD}}{R_1 + R_2}$$
Therefore
$$V_1 =I*R_2 = \frac{V_{DD}}{R_1 + R_2} * R_2 = V_{DD}\frac{R_2}{R_1 + R_2}$$
Next, we turn off the voltage source and the circuit becomes:
And the voltage at \$V_{FB}\$ is now equal to:
$$V_2 = -R_1||R_2 \times I_{FB} = - \frac{R_1 \times R_2}{R_1 + R_2} I_{FB}$$
So the \$V_{FB}\$ is equal to \$V_{FB} = V_1 + V_2\$
$$V_{FB} = \frac{ V_{DD} R_2}{R_1 + R_2} - \frac{R_1 R_2 I_{FB}}{R_1 + R_2} = \frac{R_2(V_{DD} - I_{FB}R_1)}{R_1 + R_2}= R_2 \times \frac{V_{DD} - I_{FB}R_1}{R_1 + R_2}$$
So the equation gives by Ti is correct.
