I am working on hooking up a potentionmeter as a speed control input to a variable frequency drive.
Here is are the diagrams from the VFD manual:
(Its a Lenze AC Tech SMVector ESV112N01SXB; full manual)
The potentionmeter I have does have 3 terminals and appears to go up to 10 kOhm.
Based on the definitions of terminals 2,5,6 I find it confusing to understand what is required. Especially #2 "analog common" (common what?)
Since a potentiometer is basically just a resistor, I had the impression that it would only need the pot center and one of the other two, not both.
If I do not actually need to wire all three, which of 2, 5, 6 actually should be used?
Possibly I could just try it various ways and experiment ... but I'd prefer not to risk damaging the device (assuming that's possible with these connections).
I hope to come out of this actually understanding how it should work, not just wiring tips. Thanks!
