Hello I’m quite new to electrical work and I’m trying to open and close a solenoid valve with a battery. I have bought these tiny 23a 12v battery. The solenoid says it needs 12v dc. I have no idea why it’s not opening all Insaw were some sparks. The battery can output 55mA but other than that I can’t tell you much. If anyone could tell me what battery I should use it instead that would be great as I wasted money on these batteries and I don’t want to waste money on other batteries that don’t work
    \$\begingroup\$ How much current does the solenoid need? My guess is that that poor 23a battery cannot deliver enough power. Maybe 8 AA batteries in series will do the job. Yes that's a lot of batteries but such a solenoid might need quite some power. If you have a 12 V power supply or a 12 V car battery, that would also work. 23a batteries are for low power applications like garage door remote control. \$\endgroup\$ – Bimpelrekkie Sep 15 '20 at 9:08
  • \$\begingroup\$ What do you mean how much current? Also, I was maybe thinking on buying like 2 9v batteries in series but I’m not sure. \$\endgroup\$ – import_hill Sep 15 '20 at 9:10
  • \$\begingroup\$ 2 9V batteries in series give the wrong voltage and most probably wouldn't deliver enough current to switch the solenoid either. Well, maybe once, but not repeatedly. \$\endgroup\$ – ocrdu Sep 15 '20 at 9:24
    \$\begingroup\$ What do you mean how much current? Look on the sticker on the solenoid, does it mention current or power? If the solenoid needs for example 1 A then the 55 mA (0.055A) of that 23a battery is by far not enough. \$\endgroup\$ – Bimpelrekkie Sep 15 '20 at 9:36
    \$\begingroup\$ The solenoid wants 12V, so 18V is too much; if the batteries manage to put through enough current (they are small, so probably not), the coil might fry. After one or two activations, the small 9V batteries wil probably be empty, even when they can deliver enough current to activate the solenoid. \$\endgroup\$ – ocrdu Sep 15 '20 at 11:49
Looking at the size of the solenoid: that thing is meant to have a lot of power.
Your battery is not meant to provide a lot of power, at all.
This won't work.
You need a battery with higher current capacity. How much – hard to tell, but maybe the label or definitely the datasheet of the solenoid would tell you.
To test, use a 12 V power supply that is certainly able to drive this (a lab power supply, a car battery, …), and measure the hold current, and if you have an oscilloscope, also measure the turn on current. Then you'll know what kind of current your battery needs to source, and then you can pick a battery.
Those tiny batteries can't deliver the current the solenoid needs to activate. How much current it needs depends on the type of the solenoid.
You could try with 8 AA batteries in series, or a 12V Sealed Lead Acid battery, but for a definite answer we would need to know the specifications of the solenoid, and how often you plan to activate it.
