I need to replace the capacitors on a blower motor, they heated and leaked. I couldn't find much capacitors that are compatible with the casing and has the same rating as the old ones. I however managed to find this one on Digikey.
https://www.digikey.ca/short/z2jwbb
The original ones are two 'All Earth 50uf 250vac 60/50' connected in parallel acting as one capacitor. The one I found on Digikey has 4 terminals, 2 on each side, while the old one only has 2, 1 on each side.
I tried reading the datasheet but couldn't find much information about the terminals connection. Why is there 4 terminals on the one I found and will it work if I replace the old ones with this one.
I have attached two images of the old ones.
