I found this two TVS diode and there is a difference in the diagram of the diode representation.
Common Cathode: https://www.mouser.com/datasheet/2/389/dm00207446-1798715.pdf
Common Anode: https://www.mouser.com/datasheet/2/427/vcan16a2-03g-1713959.pdf
Is there any difference between this two? Or one of them is wrong?
  • \$\begingroup\$ Shouldn't be any functional difference between the two: the path only conducts when the voltage across it exceeds one forward diode drop plus one zener drop - doesn't matter in which order. \$\endgroup\$
    – td127
    Sep 15, 2020 at 18:10
  • \$\begingroup\$ None of they are bidrectional TVS diodes. \$\endgroup\$
    – DKNguyen
    Sep 15, 2020 at 18:35
    \$\begingroup\$ yes, they are. Both are a two line bidirectional TVS. \$\endgroup\$ Sep 15, 2020 at 18:49
  • \$\begingroup\$ Do you guys think the physical arrangement of the semi-conductors matches the symbols? \$\endgroup\$
    – Drew
    Sep 15, 2020 at 19:29
According to this Onsemi datasheet: https://www.onsemi.com/pdf/datasheet/mmbz15vdlt1-d.pdf Note: the dual common anode zener configuration shown above is electrically equivalent to a dual common cathode zener configuration
