I’ve got BMS board without balancing feature and a balancing board. I want to know how to connect them to make a battery pack.
    \$\begingroup\$ Read the datasheets and connect them up accordingly. Without the datasheets there is very little we can suggest. Are you sure these two boards will be compatible with each other and with your battery pack? \$\endgroup\$ – Puffafish Sep 16 at 8:38
    \$\begingroup\$ @baouissi: You need datasheets from the manufacturers that show how each board is intended to be connected. Photos alone don't do much good. \$\endgroup\$ – JRE Sep 16 at 9:45
