I have an existing system that I wish to replace one of these Infineon TLE52062GAUMA1 motor drivers in. It's a H-bridge 40V/5A driver in a TO263 package. (https://ie.farnell.com/infineon/tle52062gauma1/motor-driver-h-bridge-to-263-7/dp/2480504)
It turns out that the device is obsolete and unavailable from Mouser, Digikey, RS etc. I might be able to get it from other suppliers like TME (I'm in Europe), but I have never dealt with them before and anyhow the part is only available until they run out, which is not helpful for the future. Ideally I'd like a pin-compatible and functional replacement that is readily available. I'd be grateful for any information on this. Infineon don't seem to have a replacement, but maybe there is another manufacturer with something close enough.
  • \$\begingroup\$ You would like to repair or make a new device? \$\endgroup\$ – Marko Buršič Sep 16 '20 at 13:00
  • \$\begingroup\$ Its a repair, I look after a lab with several of these systems, so would be nice to have a reliable source of spares rather than buy a load of obsolete parts just in case. \$\endgroup\$ – JMcC Sep 16 '20 at 14:46
  • \$\begingroup\$ You might need to use something else on its own module and load terminals and tap out the control signals. \$\endgroup\$ – Chris Stratton Sep 16 '20 at 15:18
  • \$\begingroup\$ I'm sure hoping to avoid that, but I accept it is possibly all I can do. There is not a lot of space in there, but it is doable..... \$\endgroup\$ – JMcC Sep 16 '20 at 15:27
