Am I right that when MOSFETs are connected in parallel for them to share the current equally (See Parallel MOSFETs) they have to be operated in the triode region?
I have an electronic load with 3 parallel MOSFETs and one opamp with 1 shunt in the negative feedback configuration with the opamp driving all 3 MOSFET gates and when in the active region all the current goes through one of the MOSFETs.
What is the easiest way to get a more even current distribution in the active region in this application?
basic electronic load
    \$\begingroup\$ Likely, use a 20mΩ sense for each one, and drive each gate individually. \$\endgroup\$ – rdtsc Sep 17 '20 at 23:03
  • \$\begingroup\$ What is the minimum voltage drop and maximum current required? \$\endgroup\$ – Bruce Abbott Sep 17 '20 at 23:04
  • \$\begingroup\$ @BruceAbbott, Minimum voltage drop as low as possible, max current - 10A. I was testing at the voltage drop of 36V and the current 1.5A when it was very noticable that all the current was going through one MOSFET. \$\endgroup\$ – axk Sep 17 '20 at 23:28
Yes, that is quite correct but, you could get lucky and have a reasonably even spread. When operated in their linear region not only is the current sharing ambiguous but one device can really hog all the current due to the gate-source control voltage being below the zero-temperature-coefficient point. The knock-on effect of this is that all three devices can blow up within milli-seconds.
Reason: one hogs all the current demanded as by the control circuit and it gets warmer and takes more drain current before the control system can respond and you are in a vicious circle where the device fails rapidly in a hot-spot area inside the silicon. It's called the spirito effect.
Once this happens (and it can happen as quickly as a few tens of microseconds) the remaining MOSFETs (previously not called into action) are "forming a queue" for it to happen to them.
Well if there is a silver bullet it's three op-amps and three current sense resistors; not elegant but practical; three parallel and independent current sources/sinks.
More on the Spirito Effect in questions and answers on this site: -
  • \$\begingroup\$ With perfect MOSFET your answer would be untrue, but there are no perfect components, they have variations. I have also heard that this phenomena is called "Wolf pack", the weakest sheep is caught first and then the second and so on... \$\endgroup\$ – Mats Karlsson Sep 18 '20 at 6:14
  • \$\begingroup\$ If there was a god for MOSFETs my answer would also be untrue but there isn't. I'm also thinking that you haven't realized that this can happen to a single MOSFET if operated below the ZTC point @MatsKarlsson. Thermal runaway in a single MOSFET is a fact despite the believed myths about MOSFETs. \$\endgroup\$ – Andy aka Sep 18 '20 at 6:21
  • \$\begingroup\$ Thanks! Didn't know I should have stayed away from low Rds_on MOSFETs for this application to avoid the Spirito Effect. Hope it works for the short duration application I need it for. Hasn't exploded so far :) \$\endgroup\$ – axk Sep 18 '20 at 20:42
    \$\begingroup\$ It affects the MOSFET saturation region. Most data sheets show graphs if you compare yours with graphs in the other links I provided. \$\endgroup\$ – Andy aka Sep 18 '20 at 21:45
    \$\begingroup\$ IXYS have a good range and this device looks like it might converge off the graph to the right. However, if you look how much ID changes with temperature it isn't a great deal ratio wise compared to MOSFETs suitable for switching applications. In other words, where ID is greater, the relative change of ID with temperature is not massive. \$\endgroup\$ – Andy aka Sep 21 '20 at 6:08
