I need some advice about how to provide a DC voltage (between 0 and 24V, tunable) with high current (about 8A) to a motor.
All the times I have done this, I have used a BJT Darlington pair like this one, with BDX53C and BUV20:
At left we have a tunable biasing network which provides a voltage between 0 and a bit more than 24V (to get exactly 24V at the emitter of the BUV20.)
My problem with this type of configuration is heat of BUV20: it becomes too hot and it is difficult for me to keep it cool although I use a 100x100 mm heatsink and an 80mm fan (with also thermal paste.)
What I need is another final stage which generates less heat. I was thinking of replacing my Darlington pair maybe with a power MOSFET, but I do not know how to choose it regarding its "thermal behaviour." In other words, I do not know how to quantify (with datasheet parameters) how much a certain transistor generates heat at a certain biasing condition.
Which configuration and which transistors do you think may be good for my purpose?
  • \$\begingroup\$ Why is the transistor on the high side? Why is a freewheeling diode missing? Why not a bog standard low side MOSFET? \$\endgroup\$
    – winny
    Sep 18, 2020 at 7:19
  • 7
    \$\begingroup\$ It is pointless to ask for a "better" transistor when the the way in which the speed is controlled relies on "burning off" the excess power. This type of speed regulation system results in the transistor getting hot, there is no way around that. If you want the transistor to be cooler you need better cooling or a use a different way to control the speed using a switched mode speed controller. \$\endgroup\$ Sep 18, 2020 at 8:03
  • 5
    \$\begingroup\$ @tlfong01 your first comment is misleading. \$\endgroup\$
    \$\begingroup\$ @Kinka-Byo, I might have misunderstood your phrase " final stage". I might have wrongly thought that your "final stage" is a power switch, and the previously stage is either a linear or switching mode PSU. If your PSU is not switching mode, then I would suggest to use a switching mode PSU instead. Switching mode PSU is usually 90% efficient. For example, if your linear PSU steps down from 24V to 12V, 50% power is wasted as heat, but a switching PSU only wastes 10% energy as heat. My apologies for any possible misunderstanding. Cheers. \$\endgroup\$
    – tlfong01
    Sep 18, 2020 at 8:14
  • 4
    \$\begingroup\$ @tlfong01 "But power BJT is very outdated, inefficient design." - If you're using a transistor in its linear region to drop a large-ish voltage, there's no difference between BTJs and MOSFETs in heat generated. In fact, for such a linear application, BJTs are often still preferred. Even for switches, high-efficiency BJTs definitely still have their place, competing with MOSFETs. - "I would suggest to use a switching mode PSU instead" - which is basically what I suggested in the second comment ;) \$\endgroup\$
    – marcelm
    Sep 18, 2020 at 16:41
7
+1 on what Andy said.
Not what you asked, but what you need is a bog standard low side N-FET PWM driver.
Such a device is most likley available on eBay as is. An adjustable 24 V, 8 A capable buck converter would also solve your problem. eBay link
  • \$\begingroup\$ Thank you for your advices and for the precious ebay link. A last question about your schematic: why if we drive the final transistor (in this case M1) with PWM instead of a potenziometer, we get less heat? I do not understand the physics behind this... \$\endgroup\$
    – Kinka-Byo
    Sep 18, 2020 at 8:27
    \$\begingroup\$ @Kinka-Byo By driving it with PWM the MOSFET is on or off (most of the time) so in a low or high resistance state, which leads to lower power dissipation. \$\endgroup\$
    – Colin
    Sep 18, 2020 at 8:32
    \$\begingroup\$ @Kinka-Byo Look up the terms SMPS and PWM. Transistors have very litte power dissipation when they are fully blocking or fully conducting. This is used in bilions of power supplies around the world to cut cost and losses. \$\endgroup\$
    – winny
    Sep 18, 2020 at 8:45
  • \$\begingroup\$ Very clear! Thank you very much again. Another (the last) question: why will the motor be driven by a voltage and not by a current in such schematic? It is put between 24Vdc and Drain of M1: so I'll say it will receive a fixed current (depending on Vgs and so on the cursor position of the potentiometer), and not a fixed voltage. Is this a voltage source or a current source? \$\endgroup\$
    – Kinka-Byo
    Sep 18, 2020 at 9:09
    \$\begingroup\$ @Kinka-Byo You are most welcome. Voltage source. For simplicity. There are special cases where you want to control the torque of the motor via current control, but for your majority of applications voltage control (proportional to no-load speed) is good enough. If you need constant torque control, you will do that via current sense and feedback to your voltage control. \$\endgroup\$
    – winny
    Sep 18, 2020 at 9:36
9
A linear regulator is a lossy delivery system especially when coping with high load currents. No matter what output transistor you choose, the same heat power will be generated. So, if you stick to linear operation, the only option is to provide a better heatsink to remove the heat power more effectively and thus lower the temperature of the transistor.
Or, use a switched mode controller.
  • \$\begingroup\$ Thank you for your answer. Can you give me some indications (a possible schematic or a name of configuration) so that I can look for how to build a switched mode controller? \$\endgroup\$
    – Kinka-Byo
    Sep 18, 2020 at 8:07
  • 4
    \$\begingroup\$ I'd look for a circuit that was a buck regulator that has a control input that can vary the duty cycle out. The picture in @winny's answer is a typical configuration. I'd probably go for something like that but, if I were building myself I'd go for a push-pull MOSFET output stage (less heat) and activate the MOSFETs via a dual high-side and low-side driver (with bootstrap facility) and drive PWM from an LTC6992 into the logic inputs on the MOSFET driver. I've done a similar thing before. \$\endgroup\$
    Sep 18, 2020 at 9:10
