I am using a Master PIC18F4620, Slave DS1307. All I am doing is setting the seconds to (0) at the beginning of the program, then I read it. I can't seem to read correctly, the value that is being returned from the SSPBUF register is the Slave+Writebit Address.
Everything is perfect on HW & Simulation, how is so? I used an I2C Debugger on Proteus and it is all working fine, I am indeed writing and reading CORRECT values, I then checked using my PicKit3 Debugger HW, and I found out something very interesting. The SSPBUF DOES transmit and receive, therefore its value changes, but the assignment statement from the SSPBUF to a variable FAILS.
#include "18F4620_Config.h"
#include "I2C.h"
#include "Generic_LCD.h"
#include "stdio.h"
#define _XTAL_FREQ 16e6
#define _RTC_WRITE 0xD0
#define _RTC_READ 0xD1
#define SEC_ADDRESS   0x00 // Address to access Ds1307 SEC register
#define CONTROL 0x07       // Address to access Ds1307 CONTROL register
unsigned char seconds;
char myString[6] = {0};
void main(void)
    LCD_Init();
    LCD_Clear();
    LCD_Print("Read:");
    I2C_Master_Init();
    DS1307_Set_Seconds(35);
    while (1)
        seconds = DS1307_Read_Seconds();
        LCD_Goto(6, 1);
        sprintf(myString,"%x ",seconds);
        LCD_Print(myString);
        __delay_ms(1000);
As for the two used functions.
void DS1307_Set_Seconds(unsigned char secs)
    if (secs <= 60)
        unsigned char higher = (secs / 10) << 4;
        unsigned char lower = (secs % 10);
        unsigned data = higher | lower;
        I2C_Start();
        I2C_Write(_RTC_WRITE);
        I2C_Write(0x00);
        I2C_Write(data);
        I2C_Stop();
unsigned char DS1307_Read_Seconds(void)
    unsigned char sec;
    I2C_Start();
    I2C_Write(SEC_ADDRESS);
    I2C_Restart();
    I2C_Write(_RTC_READ);
    sec = I2C_Read_Byte();
    I2C_NACK();
    I2C_Stop();
    return (sec);
The only thing that is being printed right now is (D1) on the LCD. I noticed another strange behavior, if instead of assigning SSPBUF value to a variable, I pass the SSPBUF as a parameter to the sprintf function, IT WORKS!. Like this
while (1)
            LCD_Goto(6, 1);
            sprintf(myString,"%x ",SSPBUF);
            __delay_ms(1000);
Edit 1: Solution As mentioned in the comments, the solution is to read from the SSPBUF AFTER the I2C Communication has stopped entirely.
Therefore these are the code changes
void I2C_Read_Byte(void)
    //---[ Receive & Return A Byte ]---
    RCEN = 1; // Enable & Start Reception
    while (!SSPIF); // Wait Until Completion
    SSPIF = 0; // Clear The Interrupt Flag Bit
    I2C_Start();
    I2C_Restart();
    I2C_Read_Byte();
    I2C_NACK();
    I2C_Stop();
    return (SSPBUF);
while (1)
        LCD_Goto(6, 1);
        sprintf(myString, "%x ", seconds);
        __delay_ms(1000);
    \$\begingroup\$ Can you pinpoint the problem a bit more? Are you sure that the var “sec” gets filled with the i2c data, or is that the question? \$\endgroup\$
    – Ananas_hoi
    Sep 19, 2020 at 7:23
  • \$\begingroup\$ The problem is that the var "sec" gets filled with the I2C Slave Address? The question is why? \$\endgroup\$ Sep 19, 2020 at 13:03
I can't be sure, but I suspect the PIC is latching the address into SSPBUF, and once you read that it will then put the data there. So if you read it a second time, you'll get the data. Note that in your second example, you call DS1307_Read_Seconds(), which tries to read it, and then you read SSPBUF which would be a second read from that register.
  • \$\begingroup\$ That was worth a try, and it is indeed the correct answer. I probed into why this would be the right answer, and it seems that I only get the data from the SSPBUF, IF and ONLY IF, I read its value AFTER stopping the I2C Communication. so after the I2C_Stop() Thank you very much! \$\endgroup\$ Sep 19, 2020 at 13:12
