I am interested in estimating the max current capacity of wires made from materials other than copper, ie nichrome. I have found plenty of data on the current capacity of copper wires here
https://www.powerstream.com/Wire_Size.htm
Can I estimate the max current capacity of a nichrome wire by comparing the restistivity of copper and nichrome? Would the current capacity of nichrome wire decrease in relation to copper wire by the same factor as the difference in resistivity between the two materials, or would the difference in thermal conductivities make such an estimation too inaccurate?
  • \$\begingroup\$ Purpose is important. This might be a reasonable Q for the current capacity of aluminium, or even gold. But passing current through Nichrome is not normally done for the purpose of transmitting current. You probably want heat. How much heat? (both heat power' and temperature)? How is this wire to be supported, insulated, and cooled? These affect the solution you want. \$\endgroup\$
    – user16324
    Commented Sep 22, 2020 at 17:01
The limit for copper and nichrome wires is different in character.
Copper wires are designed to carry current without getting too hot. As such, they are rated assuming a temperature rise that will allow the insulation on them to remain intact. The rated tempertaures are usually sub 100 °C.
Nichrome wires are resistance wires, and are one of a series of alloys that are designed to get hot, and stay hot, without undue shifts in resistance and corrosion from gasses in the atmosphere. Depending on the specific alloy, it may be possible to have temperatures of the order of 1000 °C.
Thermal conductivity is not particularly relevant here. It's only when a short piece of wire is being used between large terminals, like a fuse link for instance, that the thermal conductivity limits the temperature rise of the centre of the link, due to the action of the nearby terminals as heatsinks. Both copper cables carrying current around, and long nichrome wires cutting plastics, are so long that the heatsinks at the end are irrelevant. The principal heat loss mechanism is convection and radiation from the surface of the wire.
