I have four batteries connected in parallel, I have seen diagrams showing where the output terminals are both coming off of the last battery and the parallel connection. I've also seen ones where the output terminals are on each ends of the entire battery. Which would be the correct terminals to use as output? Are there any benefits to either one?
Using opposite terminals
Using the same terminals
