I am currently trying to derive the relevance of ethernet connections shielding and grounding. This is regarding the robustness of the design (in terms of communication) and eventual ESD considerations as well. I can find the following scenarios possible (assuming 2 devices connected with an ethernet cable).
- Both devices have unshielded ethernet jacks, the cable is unshielded,
- Both devices have unshielded ethernet jacks, the cable is shielded,
- Only 1 device has shielded jack, the cable is unshielded,
- Only 1 device has shielded jack, the cable shielded,
- Both devices have shielded jacks, the cable is unshielded,
- Both devices have shielded jacks, the cable is shielded.
My assumption is that for the cases where the cable is unshielded (1, 3, 5), the shielding of the connectors is irrelevant. My questions are then regarding the points (2, 4 and 6):
- If none of the connectors are shielded, does the shielding on the cable provide any difference in terms of noise insulation or ESD?
- If only one of the devices is shielded, I assume this is the best case, since we do not have any ground loops and insulation is good. But how does it correlates with ESD? Also, in case the shielded connector device is not connected to the PE pin of the AC connector (i.e. only L and N connection available)- is this insulation effective? We can see many networked devices with a 2 pin AC adapter and shielded connectors.
- If both devices have shielded connectors (both connected to their local GND), what exact effects can it have for the whole system (incl. ground loops)? How should we look at it in terms of ESD?
I would appreciate all feedback to my questions.
