If a GPIO pin is not interrupt configurable as external interrupt, is it still possible by any chance to detect the button press on the pin without polling just like an interrupt?
    \$\begingroup\$ Seems unlikely, which micro? There may be bodges like configuring the pin as analogue and having an analogue watchdog interrupt when it goes above/below a level, or similar with a comparator or timer input capture or something. \$\endgroup\$
    – Colin
    Sep 24, 2020 at 10:07
  • \$\begingroup\$ Here it is. Please refer to page number 12. The pin is P71/GE_SPDQ0/GE_HBCSX0 35 [cypress.com/file/236586/download] \$\endgroup\$
    – Nikeboy
    Sep 24, 2020 at 10:56
  • \$\begingroup\$ @Nikeboy You must log in or register to access this page. \$\endgroup\$
    – schnedan
    Sep 24, 2020 at 11:55
    \$\begingroup\$ Depends on what other internal peripheral modules are connected to that pin. Maybe there's a timer which you could configure to generate an interrupt after a single count or something like that. Can you share some more info - which micro and which pin? \$\endgroup\$
    – brhans
    Sep 24, 2020 at 12:24
Not directly, but if you have a periodic interrupt going for other purposes you could add a poll of your button in there. If you don't, you could add a periodic interrupt at some nominal rate (20-100ms) and poll your button there (assuming this is a human-pushed button, you don't need any more resolution than that).
This doesn't save you the wasted time of reading a button that hasn't changed, but it does save you the hassle of polling in the background.
  • \$\begingroup\$ That makes complete sense. Thanks a lot :) \$\endgroup\$
    – Nikeboy
    Sep 25, 2020 at 7:57
