Today, I was repairing my soldering iron. During the repair, when I cut the end of two core wire, I found some oil type liquid surrounding both the wire. To confirm, if this is present in whole cable, I cut the wire from other place, and found the same oil type liquid surrounding both the wire there also.
4\$\begingroup\$ It's probably silicone insulation, and silicone oil. In a cable that's going to be flexed a lot during its lifetime, it's a reasonable way to reduce internal friction and extend its life. It also makes the cable more flexible than it would be if the layers couldn't slide relative to each other. \$\endgroup\$– Dave TweedSep 26, 2020 at 14:46
\$\begingroup\$ Some cables of obscure origin are made of low-quality plastic, which decomposes over time. I hope I'm wrong. \$\endgroup\$– Peter MPSep 26, 2020 at 15:32
\$\begingroup\$ Maybe your mains plug had been left dangling is some oil and, due to capillary action, sucked up oil into the cable? \$\endgroup\$– Andy akaSep 26, 2020 at 16:27
1 Answer
It's probably loss of the plasticizer in the insulation polymer. Flexible plastics like PVC (Polyvinyl Chloride) are not "just" PVC chemically. There are numerous additives to improve fire retardant properties, UV resistance and flexibility. The latter property is improved by the addition of "plasticizer" chemicals, which can make up a significant portion of the material mass. The smell of a swimming pool liner is not the polymer, but the plasticizer. Loss of the plasticizer over time results in gas and/or liquids leaving the plastic and embrittlement of the insulation. Dibutyl phthalate is one example of a plasticizer that is an oily liquid.
Additives of various kinds (in addition to the above-mentioned ones, there are others to improve processing characteristics and to reduce high temperature dechlorination in PVC, for another two examples) have a history of causing problems. High lead levels in homes were found to be a caused by inexpensive (about $10K for a sea-shipment container full, FOB Taiwan) plastic Venetian blinds back in the 1970s. Turns out the manufacturers were using lead as a stabilizer in the plastic and the plastic broke down slowly under UV light (as window blinds are exposed to) and a fine dust containing lead resulted. More recently, some very effective fire-retardant additives have been banned because they are carcinogenic. Other chemicals such as BPA have effects that are disputed, with the EU generally being more eager to ban suspected problem chemicals, and the US EPA being more reluctant to impose costs on business.
I've seen this oily ooze mentioned in regard to Western Electric phone cords and guitar amplifier line cords from the 1960s and other wiring.
