just like the title says, I'm trying to figure out the duty cycle of a GPS's Pulse Per Second Signal. This post and accompanying answers seem to indicate something like a 10% duty cycle: GPS PPS signal corresponds to data time?
Whereas the waveform shown at 2:43 in this youtube video show something like a ~25% duty cycle: https://www.youtube.com/watch?v=GAtL5sFmlQg
Is it variable? Is there a standard? I also crawled wikipedia and some of the documentation links to military standards there, but it was a little dense for me and I didn't see anything really jump out... thank you for your kind and generous help!
  • \$\begingroup\$ The actual knowable technical situation is surveyed at the question you link GPS PPS signal corresponds to data time? - the key practical information you may be missing is that you should not make a system depend on the duty cycle, rather you should depend only on the active edge which appears to be the leading one at least for the receivers mentioned there. \$\endgroup\$ Oct 2 '20 at 19:14
