I am working on a design that uses a W5500 for networking. I followed a reference schematic and believe all my connections are correct, however I am facing issues with the network connectivity.
Basically, the device thinks that the link is always on. The Link LED turns to yellow about 1 sec after booting and stays on, even if I plug in an Ethernet cable from a router or if there is nothing plugged in.
Schematic:
Wiznet W5500 Reference Schematic:
I've included the schematic here. I am using a Chinese HANRUN RJ45 connector with POE functionality.
Does anyone know why this is or could be happening? I have followed the reference schematic and the only thing I can think that is different from the reference is the reset and the RJ45 connector.
I checked reset. It's sitting HIGH at 5 V. It needs to go low for >500 us to reset. Hitting the reset button correctly resets the device.
I should mention I did my testing with Arduino software. I used Examples -> Ethernet -> Link Status. Even when there is nothing plugged in, I get Link: ON.
Thanks for any help in advance. I will be checking back and trying to answer as many questions as possible
