This post is regarding exersise 4-8 from the following book: Hughes Electrical And Electronics Technology 10th Ed.
Here it is:
Let's focus on what I tried for solving part (b) :
Since this is an exercise under the chapter for delta-star transformations my first thought was to try and perform some such transformation. However this was a combination of both star and delta connections so I didnt really know whether the resulting resistances would be in series / parallel or neither, with the already existing ones, so I tried both series and parallel: enter image description here
However neither worked.
My next thought was that maybe I have understood something very badly about the resulting resistance of two points in a circuit. So after a little bit of digging I tried the following: enter image description here
However I again got a wrong result in regards to the given answers at the end of the book.
Conclusion:
  • Which approach (if any) was correct?
  • If no approach was correct, which concept do I need to understand better?
Any help/hint is very much appreciated
  • \$\begingroup\$ I don't think any of your approaches makes sense and also you didn't explain anything how you draw these equivalent circuits \$\endgroup\$
    – user215805
    Oct 3, 2020 at 17:35
  • \$\begingroup\$ Take the delta, transform into a star. You have two start in parallel which is easy to simplify. Or take the star. transform into a delta. Two deltas in parallel. Or both, transform the final delta into a star (or vice versa) to check you get the same answer. \$\endgroup\$
    – user16324
    Oct 3, 2020 at 18:33
  • \$\begingroup\$ @BrianDrummond this is what it tried(first picture), i guess i made some computational error, will try again \$\endgroup\$
    – Stamatis
    Oct 4, 2020 at 7:16
  • \$\begingroup\$ @BrianDrummond I have concluded that i have not made any computational mistake, the resulting Resistance from A to N turn out to be 0.98 ohm with this method, which by the book is wrong, it should be 1.45 ohms \$\endgroup\$
    – Stamatis
    Oct 5, 2020 at 9:14
    \$\begingroup\$ @BrianDrummond it worked for part (a) however so I am clearly doing somethiing wrong \$\endgroup\$
    – Stamatis
    Oct 5, 2020 at 9:29
To calculate equivalent resistance between A and N one approach would be -
1.look at NCB which is in Delta connected form
2.make NCB in star connection from delta by conversion formula
after that conversion you'll get a very simlified circuit which is very easy to solve
  • \$\begingroup\$ I see what you mean, and it worked, I posted the full solution as an answer here. Thank you so much! \$\endgroup\$
    – Stamatis
    Oct 5, 2020 at 10:58
I figured it out, this is the answer for part(b) "Finding Equivalent resistance from A to N".
First of all, here is a nicer sketch:
Now we will focus at the delta connection defined by N , B , C :
And now if we go back to our original sketch and replace the converted circuit we can greatly simplify it:
Finally, we are ready to compute the equivalent resistance from A to N:
