This appears to be a legal question so: I am not a lawyer and this is not legal advice. Now that's out of the way, it seems that you indeed need to place a CE mark on your product. Here is what the legislation in the U.K. requires:
Requirements for placing on the market
- No person shall place on the market apparatus unless either the following requirements, or the corresponding requirements of the EMC
Directive as implemented under the law of another state in the
Community, are met—
(a)the apparatus is compliant with the essential requirements;
(b)compliance with the essential requirements has been demonstrated in
accordance with regulation 18;
(c)the technical documentation
including any statement issued by a notified body under regulation 20
has been prepared and is available to the enforcement authority on
request;
(d)the CE marking has been properly affixed by the manufacturer or his authorised representative in accordance with regulation 21;
(e)an EC declaration of conformity has been issued in
accordance with the requirements of regulation 22;
(f)each apparatus
is identified in terms of type, batch, serial number or any
information allowing for identification of the apparatus;
(g)each
apparatus is accompanied by the name and address of the manufacturer
and if he is not established in the Community, the name and address of
the responsible person;
(h)the manufacturer has provided information
on any specific precautions that must be taken when the apparatus is
assembled, installed, maintained or used in order to ensure that when
put into service the apparatus complies with the essential
requirements;
(i)apparatus for which compliance with the essential
requirements is not ensured in residential areas is accompanied by a
clear indication of this restriction of use and where appropriate this
indication is also on the packaging; and
(j)the information required
to enable the apparatus to be used in accordance with its intended
purpose is contained in the instructions accompanying the apparatus.
This is from The Electromagnetic Compatibility Regulations 2006. Look at (d). It specifically prohibits you to put a device on the market, if you have not affixed the CE marking to the device, or to the packaging, if there is not enough space, as stated in 21.
An apparatus is defines as:
3.—(1) In these Regulations, “apparatus” means any finished appliance or combination of appliances made commercially available as a single functional unit, intended for the end user and liable to generate electromagnetic disturbance, or the performance of which is liable to be affected by such disturbance and includes—
(a) components or sub-assemblies intended for incorporation into an apparatus by an end-user, which are liable to generate electromagnetic disturbance, or the performance of which is liable to be affected by such disturbance;
(b) mobile installations defined as a combination of apparatus and, where applicable, other devices, intended to be moved and operated in a range of locations;
The only exceptions are:
- The requirements in regulation 15 and 16 shall not apply to—
(a)the placing on the market of apparatus before 20th July 2009; and
(b)the putting into service of apparatus placed on the market before
20th July 2009, where, on or before 19th July 2007, a declaration of
conformity in respect of such apparatus has been issued by the
manufacturer or his authorised representative pursuant to Article 10.1
or 10.2 of Directive 89/336/EEC as implemented in the United Kingdom
to enable it to be placed on the market or put into service, or both.
And electromagnetically benign equipment:
- These Regulations do not apply to equipment the inherent qualities of which are such that—
(a)it is incapable of generating or contributing to electromagnetic
emissions which exceed a level allowing radio and telecommunication
equipment and other equipment to operate as intended; and
(b)it will
operate without unacceptable degradation in the presence of
electromagnetic disturbance normally consequent upon its intended use.
