I am using a simple code to read from ADC pin A0. When I read from ADCH and ADCL. The result is correct only once in the startup. When I change the analog value in A0, output from the ADC don't change at all. Unless I have reset the mcu.
In the datasheet it is not state clearly that there is a register called ADC. They highlight ADCH and ADCL.
reading from register ADC work fine.
This is my simple code that don't work.
* Section: Function Defintion
void ADC_Setup(){
// Enable the ADC
ADCSRA |= 1<<ADEN;
// Select the refence voltage to be AVcc, which is connected to Vcc in the Arduino Nano board
ADMUX |= 1<<REFS0;
// Set Prescaler to 128, so that the ADC clock is 16M/128= 125Khz
ADCSRA |= (1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);
ADCSRA |= (1<<ADSC) | (1<<ADATE) | (1<<ADIF) | (1<<ADIF);
sei();
void ADC_StartConvert(){
ADCSRA |= (1<<ADSC);
uint16_t ADC_read(){
uint16_t i = ADCH*256 + ADCL;
// if changed to i = ADC; it work fine!!
return i;
What is could be the cause to make the ADC hold conversion because of reading from ADCL?
uint16_t i = (uint16_t) (ADCL + (ADCH*256));
becouse ADCL must be read first, then ADCH \$\endgroup\$ – G36 Oct 5 '20 at 15:09
