A SystemVerilog module using an always@ block with a gated trigger does not compile in Quartus Prime Lite (20.1). Quartus Prime reports the following compiler error message:
Error (10170): Verilog HDL syntax error near text: "iff"; expecting ")".
However, the "iff" conditional in the always@ sensitivities list is SystemVerilog-2005 compliant. The module does successfully compile and simulate using ModelSim-Intel Starter Edition.
The following is the SystemVerilog code:
module always_ff_process();
reg [7:0] sum,a,b;
reg parity;
logic clk = 0;
reg rst = 0;
initial begin
$monitor ("@%g clk = %b rst = %b a = %h b = %h sum = %h parity = %b",
$time, clk, rst, a, b, sum, parity);
#1 rst = 1;
#5 rst = 0;
#2 a = 1;
#2 b = 1;
#2 a = 10;
#2 $finish;
end
always #1 clk ++;
// use of iff makes sure that block does not get
// triggered due to posedge of clk when rst == 1
always_ff @(posedge clk iff rst == 0 or posedge rst)
begin
if (rst) begin
sum <= 0;
parity <= 0;
$display ("Reset is asserted BLOCK 1");
end else begin
sum <= b + a;
parity <= ^(b + a);
end
end
endmodule
I obtain no compiler error message using ModelSim-Intel and the following correct simulation results:
@0 clk = 0 rst = 0 a = xx b = xx sum = xx parity = x
@1 clk = 1 rst = 1 a = xx b = xx sum = 00 parity = 0
@2 clk = 0 rst = 1 a = xx b = xx sum = 00 parity = 0
@3 clk = 1 rst = 1 a = xx b = xx sum = 00 parity = 0
@4 clk = 0 rst = 1 a = xx b = xx sum = 00 parity = 0
@5 clk = 1 rst = 1 a = xx b = xx sum = 00 parity = 0
@6 clk = 0 rst = 0 a = xx b = xx sum = 00 parity = 0
@7 clk = 1 rst = 0 a = xx b = xx sum = xx parity = x
@8 clk = 0 rst = 0 a = 01 b = xx sum = xx parity = x
@9 clk = 1 rst = 0 a = 01 b = xx sum = xx parity = x
@10 clk = 0 rst = 0 a = 01 b = 01 sum = xx parity = x
@11 clk = 1 rst = 0 a = 01 b = 01 sum = 02 parity = 1
@12 clk = 0 rst = 0 a = 0a b = 01 sum = 02 parity = 1
@13 clk = 1 rst = 0 a = 0a b = 01 sum = 0b parity = 1
Both Quartus Prime Lite and ModelSim-Intel Starter Edition support SystemVerilog-2005. However, Quartus Prime Lite's compiler doesn't appear to support clock-edge gating (the "iff" conditional) even though it's legal SystemVerilog-2005. I have set the settings of both compilers to SystemVerilog and I cannot find any other applicable settings.
Please advise. Thank you!
