We were tasked to find the node voltage V. My analysys:
  • The way I approached this problem is to first make the assumptions of the state of the diodes. My guess is that D1 and D6 will be OFF while D5 will be on. My reasoning for D1 and D6 being OFF is because they have the opposite polarity from the voltage source that are parallel with them. D5 on the other hand i think will be ON because of a positive potential difference between the anode and cathode. But i'm having trouble with the state of D2 and D3.
  • My guess is that given the direction current source and the fact that current moves from higher to lower potential, D2 will be ON since D2 has the +- potential.
  • If D2 is ON, will V just be the forward voltage of the diode? In this case, 0.7 V since these are given to be silicon diodes.
    \$\begingroup\$ D3 can not be on, because of the direction of current I1. Neither can D1 and D6. \$\endgroup\$
    – Bart
    Oct 6, 2020 at 10:01
    \$\begingroup\$ having trouble with the state of D2 and D3 - maybe you meant D6 not D2? \$\endgroup\$
    \$\begingroup\$ @Batt, this is not intuition. It is just knowing the difference between reverse and forward bias. Intuition has nothing to do with it. \$\endgroup\$
    – Bart
    Oct 6, 2020 at 10:03
    \$\begingroup\$ Something you do learn (eventually) in engineering. Check and double check and especially the detail. No need to say sorry dude. \$\endgroup\$
    Oct 6, 2020 at 10:09
    \$\begingroup\$ The difference of currents through R1 and R2 is 1A, the sum of their voltages is 2V. That is enough information to calculate V. \$\endgroup\$
    – Bart
    Oct 6, 2020 at 10:47
Your intuition is correct, however you assumed that the voltage drop on the current source I1 is zero, which is incorrect. It is like to assume that a current flowing through voltage souce is zero. On the contrary - you can imagine that a current source generates whatever voltage is needed in order to cause the current to reach the specified value.
Lets consider resistor R1. Its left side is being held on voltage 1V by V1. Its right side has the voltage V, which we are looking for. The current through R1 is IR1=(1-V)/100R, flowing right.
Similarly, the current through R2 is IR2=(V-(-1V))/100R, also flowing right.
The current through both diodes D2 and D3 is I1=1A, it does not matter which diode is conducting.
Sum of the currents in point V is zero: -IR1+I1+IR2=0. Therefore:
-(1-V)/100+1+(V+1)/100=0
(V-1)+100+(V+1)=0
2V+100=0
V=-50V
  • \$\begingroup\$ Could you explain why it does not matter which diode is conducting? I had the same KCL equation through V except I included the forward voltage of D2 which I assumed was on. \$\endgroup\$
    – user263783
    Oct 6, 2020 at 11:32
  • \$\begingroup\$ It does not matter for the analysis - the sum of currents through both diodes is 1A because of the current source I1. Of cause, since the direction of current is downward, D2 actually conducts, but I did not assume it during my calculations. \$\endgroup\$ Oct 6, 2020 at 11:36
  • \$\begingroup\$ That makes a lot of sense. So the 1A already accounts for the supposedly contribution of any of diode (whichever would be on)to V? Am I understanding this right? \$\endgroup\$
    – user263783
    Oct 6, 2020 at 11:40
The way I would do this is to observe that there is 100\$\Omega\$ to -1V and 100\$\Omega\$ to +1V, which means the Thevenin equivalent at the Vo point is 50\$\Omega\$ to GND.
There is 1A flowing through D2 because of the current source so the voltage at Vo will be -50V and the voltage at the current source will be -50.7V. Anything (except an open circuit) in series with an ideal current source does not affect the current.
You can look at the circuit and see that D1 and D6 are reverse biased. D2 is forward biased (arrow goes in the direction of the current source) and D3 is reverse biased. D5 is forward biased because of the polarity of the voltages.
The current through D5 is (2V - 0.7V)/100\$\Omega\$ or 13mA. The voltage at the D5-resistor junction is -1V+0.7V = -0.3V or +1V - (0.013A * 100\$\Omega\$) = -0.3V.
  • \$\begingroup\$ Thank you for the explanation! Additional question, how would I solve for the voltage across D3? Would it just be the negative of the voltage across D2 (which is 0.7)? \$\endgroup\$
    – user263783
    Oct 6, 2020 at 12:23
    \$\begingroup\$ They share the same nodes so the voltage will be the same. It's reverse biased with 0.7V across it. \$\endgroup\$ Oct 6, 2020 at 12:26
