So im trying to simulate a simple write and read memory program in Vivado design suite.
Before implementing a clock in the sensitivity list on the process to write and read, the reading part used to work correctly in the simulation, but i changed it because the RAM block was created using fpga resources, and then i introduced the clock and now it works as intended (not using the fpga resources but the internal RAM instead), but in the simulation, something is not right, because the reading bits are not the same are the written ones.
When W_R is '0', the memory is writing, and reading in '1'. This is the testbench
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity RAM_SP_tb is
generic(
        constant memory_depth : integer := 256; -- numero de palabras de la memoria
        constant memory_lenght : integer := 8   -- numero de bits por palabra
end RAM_SP_tb;
architecture Behavioral of RAM_SP_tb is
component RAM_SP
 Port (
     data_in : in std_logic_vector(memory_lenght - 1 downto 0); -- datos de entrada
     address : in std_logic_vector(memory_lenght - 1 downto 0); -- direccion de memoria
     W_R : IN STD_LOGIC;  --Escribe con '0' y Lee con '1'
     data_out : out std_logic_vector(memory_lenght - 1 downto 0);-- datos de salida
     clk : in std_logic
    end component;
     signal data_in : std_logic_vector(memory_lenght - 1 downto 0):= "00000000";
     signal address : std_logic_vector(memory_lenght - 1 downto 0):= "00000000";
     signal W_R : STD_LOGIC := '0';
     signal data_out : std_logic_vector(memory_lenght - 1 downto 0):= "00000000";
     signal clk : std_logic := '0';
     constant clock : time := 100ns;
begin
uut: RAM_SP port map (
    data_in => data_in,
    address => address,
    W_R => W_R,
    data_out => data_out,
    clk => clk
clock_p :process
begin
    clk<='0';
    wait for clock/2;
    clk<='1';
    wait for clock/2;
end process;
stim_proc: process
begin
     -- Write data into RAM
WAIT FOR 100 ns;
ADDRESS<="00000001";
DATA_IN<="00000001";
WAIT FOR 100 ns;
ADDRESS<="00000010";
DATA_IN<="00000010";
WAIT FOR 100 ns;
ADDRESS<="00000011";
DATA_IN<="00000011";
WAIT FOR 100 ns;
ADDRESS<="00000100";
DATA_IN<="00000100";
WAIT FOR 100 ns;
-- Read data from RAM
W_R<='1';
ADDRESS<="00000000";
WAIT FOR 100 ns;
WAIT FOR 100 ns;
WAIT FOR 100 ns;
WAIT FOR 100 ns;
WAIT FOR 100 ns;
end  process;
end Behavioral;
and this is the principle module
library IEEE;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
entity RAM_SP is
  generic(
  Port (
         W_R : in std_logic;  --Escribe con '0' y Lee con '1'
         clk : in std_logic
end RAM_SP;
architecture Behavioral of RAM_SP is
    type mem is array (0 to memory_depth - 1) of std_logic_vector(memory_lenght - 1 downto 0); --Una memoria de 256 palabras de 8 bits
    signal memory : mem; --Asocio la memoria creada a la señal/palabra/constante memory
    signal addr : integer range 0 to memory_depth - 1; --Creo una señal que puede tomar valores enteros de 0 a 255
begin
    --process(address, data_in, W_R)
    process(clk)
    begin
        if(rising_edge(clk)) then
            addr <= conv_integer(address);
            if(W_R = '0')then
                memory(addr)<=data_in;
            elsif(W_R = '1')then
                data_out<=memory(addr);
            else
                data_out<="ZZZZZZZZ";
            end if;
        end if;
    end process;
end Behavioral;
i would really be grateful if anyone cold guide with the problem, and other issue that i noted is the UU data that is read when W_R is '1', when the address is '00', the data_out is supposed to be '00', but it read UU instead, and the remains readings are not on phase. What could be happening?
Delta cycle delay on addr ... you are writing to the PREVIOUS address so you write 0 to addr UUUU.... ditto reading from the previous address.
Either think through the pipeline more carefully, or compute addr before the clock edge (i.e. outside the clocked process in a concurrent assignment), or make addr a variable instead of a signal.
The phase delay on read is obvious : you read and write on the rising clock edge.
For preference, lose the obsolete std_logic_unsigned library and use numeric__std instead (I would then prefer to make Address unsigned) but that is not material to the current problem.
You can also lose
    else
because there are no tristates internal to the FPGA!
    \$\begingroup\$ OR memory(conv_integer(address)) <= data_in; and data_out <= memory (conv_integer(address)); without a variable or signal addr. It's not possible to have a memoy index out of range when the address length is 2log memory depth, e.g. address : in std_logic_vector{positive(ceil(log2(real(memory_depth)))) - 1 downto 0); with a use clause use ieee.math_real.all;. (Can use the -2008 equivalent of std_logic_unsigned.conv_integer, numeric_std_unsigned.to_integer). \$\endgroup\$
    – user8352
    Oct 6, 2020 at 23:04
  • \$\begingroup\$ And what does user8352 meant with "its not possible to have a memory index out of range when....", is there something wrong to the way i did it or is just an option. \$\endgroup\$
    – esencia
    Oct 7, 2020 at 0:27
  • \$\begingroup\$ @esencia I'm not clear on that. It's not even true since a 6k memory needs an address length capable of addressing 8k. What you have done works ... but it is fragile. It relies on memory_depth being 2**memory_lenght (sic). I would add an ASSERT with severity FAILURE to catch errors in the generics, or a check that address is in range if you wanted to allow a mismatch. Either of these can catch bugs faster and eliminate a bunch of time wasted during verification. \$\endgroup\$
    – user16324
    Oct 7, 2020 at 14:07
