Assumptions
- AFAIK, the sequence of the rotations are also important. It is not given in the question. I will assume the sequence to go from inertial frame to body frame is (Yaw, Pitch, Roll) = (Z, Y, X). So the sequence to go from body to inertial is the reverse.
Since these details are not present in the question, I assume the convention given in Link 1 and Link2.
- Accelerometer frame is same as IMU reference
The transformation
The measured vectors are obtained in IMU (accelerometer) frame. To take a vector resolved in IMU frame, to inertial(?) frame, the transformation as given in the above reference is
\begin{bmatrix}
v
\end{bmatrix}^I_{3\times1}
\begin{bmatrix}
C\psi & -S\psi & 0\\
S\psi & C\psi & 0\\
0 & 0 & 1\\
\end{bmatrix}
\color{red}{
\begin{bmatrix}
C\theta & 0 & S\theta\\
0 & 1 & 0\\
-S\theta & 0 & C\theta\\
\end{bmatrix}
\begin{bmatrix}
1 & 0 & 0\\
0 & C\phi & -S\phi\\
0 & S\phi & C\phi\\
\end{bmatrix}
\begin{bmatrix}
v
\end{bmatrix}^{IMU}_{3\times1}
The red matrices indicate what I assume is the transformation equation set shown in the question.
Assume the magnetometer data was available in the same frame of reference as the accelerometer. Let that reading be \$[x_M', y_M'z_M']^T\$.
\begin{bmatrix}
x_{M2}\\
y_{M2}\\
z_{M2}
\end{bmatrix}
\begin{bmatrix}
C\theta & S\phi S\theta & C\phi S\theta\\
\dots & \dots & \dots
\end{bmatrix}
\begin{bmatrix}
x_{M}'\\
y_{M}'\\
z_{M}'
\end{bmatrix}
Since the Y and Z axes are inverted for the magnetometer, the above equation changes to
\begin{bmatrix}
x_{M2}\\
y_{M2}\\
z_{M2}
\end{bmatrix}
\begin{bmatrix}
\end{bmatrix}
\begin{bmatrix}
x_{M}\\
\color{red}{-}y_{M}\\
\color{red}{-}z_{M}
\end{bmatrix}
The above is significantly different from your equations.
Sanity check
You have mentioned in the comments that "pitch on y axis". This means that a rotation about pitch should leave the Y component of a vector unchanged (if it was the last operation performed). Equation for yM
in the question doesn't seem to satisfy that logic. Of course, This check is only correct assuming a certain sequence of rotations.
Note
I see that your equations seem almost correct if the sequence of rotations to go from inertial frame to body frame is (Yaw, Roll, Pitch). The negation on Y and Z components before applying the equations are still required. So, see if your output becomes correct if you insert
yM = -yM;
zM = -zM;
just before the transformation.
pitch
,yaw
, androll
are defined ? 2) Can you add a diagram ? 3) "i think i am using the equation wrong". What makes you think so ? If the hardware is already set up, can you simply test the results at known positions ? \$\endgroup\$ – AJN Oct 8 '20 at 12:09YA = -YM
andZA = -ZM
andXA = XM
, simplest scheme is to invert the magneto metery
andz
readings so that the new, virtual, axes of magnetometer and the axes of the accelerometer become the same. \$\endgroup\$ – AJN Oct 8 '20 at 12:12
