I am working with two industrial cameras that I want to trigger synchroniously through hardware triggering. For this the STROBE_OUT pin (which is an open drain pin) from one camera (Master camera) does trigger the other camera (Slave camera) when an image is taken by the master camera.
The camera manufacturer gave me an connection schematic on how to connect the pins of both cameras.
The connections diagram they gave me looks as follows:
From the datasheet of the camera I know that the STROBE_OUT pin is a mosfet open drain configuration (pin 2 with corresponding ground on pin 1). The TRIGGER_IN (+/-) pins internal connections are given below (pin 3 and 4):
This way of connecting it really seems strange to me. In my understanding, when the mosfet is closed the pin 3 of the slave would be pulled to ground, but when the mosfet is open the pin 3 would be in a floating state, am I right? In my understanding this could lead to undefined behaviour?
I would rather assume do a connection with a pull up resistor for example something like the one below:
(Sorry for that ugly drawing)
Am I misunderstanding something here? What would be the proper way of connecting this?
