I am designing a large loop antenna working at 125 kHz. To maximize the range of my system I am aiming for 1m diameter loop antenna with as many turns as I can allocate (e.g. ~100 for 18 AWG). I have succesfully designed antennas of diameter=40cm with L=5mH. However, when trying larger geometries (or smaller wire gauge) the antennas turn out to be purely capacitve. What do I need to consider to avoid this issue?
Stop doing 'as many turns as I can allocate' and start doing 'the right number of turns'.
As the loop gets larger, the self capacitance and the inductance increase quicker than you think, and you don't need as many turns.
Start with one or just a few turns of your target size, and see what capacitor is needed to resonate it down to 125 kHz, or see what the frequency is for your target capacitor. Then calculate the inductance, and increase the number of turns by the square root of the ratio. You will need to iterate again, as increasing the number of turns will have increased the self capacitance again, but it will get you closer. Rinse and repeat, until you get a capacitor size you like.
  • \$\begingroup\$ Exactly correct. \$\endgroup\$
    Oct 9, 2020 at 9:59
    \$\begingroup\$ great answer... it could be improved slightly by some instruction / procedures on how to "see what capacitor is needed to resonate it down to 125 kHz" and/or how to "see what the frequency is for your target capacitor [and] calculate the inductance" by way of a hypothetical worked example. \$\endgroup\$
    – vicatcu
    Oct 9, 2020 at 12:32
