I need two join two traces of different widths, I use two different width at first place due to space constrains at some parts of the board. so what is the best method to do it elegantly and with no etching problems? enter image description here
    \$\begingroup\$ This is basically a limitation of cheap PCB software. There are a few historical arguments of theoretical concern with acute inside corners, etc in primitive etching process, in practice in a modern ones it works well enough, so the extreme complexity of creating software to nicely fillet or blend these things isn't considered worthwhile. There are a few ways you can game the stock behavior to be a little less ugly, listed below... \$\endgroup\$ Oct 11, 2020 at 15:13
4 Answers 4
If the smaller width works, this will also not be an etching issue. Also, this is a DC line, so you don't have to worry about anything geometrically here.
elegantly
You're asking about æsthetics here. Well, can't help you with that, honestly, different people find different things pretty. It might be prettier to simply not have the thicker line extend this far up, so that the rounding doesn't extend beyond the upper edge of your thinner trace.
But honestly, go with what you layout software does.
As long as you obey the 'design rules' of your pcb supplier, you can do whatever you like with pcb trace width and not worry about 'etching problems'.
It's entirely normal to reduce the width of traces where space is limited. It's sometimes called 'necking'.
Remember that power traces usually need to be wider than others.
That aside, your board will likely appear 'neater' if you standardise on one trace width for signals.
There's no problem with manufacturing it as shown if the design rules are not violated.
It's aesthetically ugly, but it will work. Here is the more usual way of changing trace width in mid-trace in Altium:
By not changing the direction simultaneously with the trace width it is more pleasing to the eye, at least I think so.
Of course if you're running traces with controlled impedance or pairs with controlled differential impedance you have to be a bit more careful.
  • \$\begingroup\$ It's not even that ugly TBH ! \$\endgroup\$ Oct 11, 2020 at 16:56
Stop the fatter trace short of the corner (by the difference in radius between the traces), and make an L on the thinner one.
Is it worth the effort? That's up to you.
It might be if the trace above continued past, and the blob violated spacing rules.
