7
I wish to expose a usb flash drive and read it as raw binary data, particularly read each byte & simultaneously writing it to another flash drive.
Given that I am working with an 8085 microprocessor, & I am in a position to program it & read data from secondary memory device, how can I start working with the usb.
I have tried to understand USB from this:
http://www.beyondlogic.org/usbnutshell/usb1.shtml
But I still have no idea how I would be writing my program to host flash drives.
  • \$\begingroup\$ Your project would be drastically similar if you could use SD cards (or SPI flashes) in place of USB sticks. \$\endgroup\$ Commented Oct 30, 2014 at 15:55
FTDI's Vinculum embedded USB host may be of interest to you.
It handles most of the protocol details, and gives you SPI/FIFO access to the USB Device.
  • \$\begingroup\$ +1 embedded host - you can't talk to the flash drives without it. This is the hard part...most of the literature that's available focuses on embedded devices or full-sized PC host controllers. \$\endgroup\$
    – ajs410
    Commented Oct 18, 2010 at 17:38
    \$\begingroup\$ @ajs410 - well, you could talk to a flash drive without it, but you'd have to write a soft-usb-host, and that's an exercise for the masochistic only. USB is rather complex under-the-hood. \$\endgroup\$ Commented Oct 10, 2011 at 10:04
I would look for a reference design for both the hardware and software to get you going. The website you have linked to is good night time reading and background, but actually implementing have a search for some code examples.
Check this site from Atmel, it has some software examples for the various 8051 subsystems and should help you get going for USB.
http://www.atmel.com/dyn/products/tools.asp?family_id=604#1535
http://www.ghielectronics.com/catalog/product/6 This company has some products to allow interaction between selected usb devices and mcu's and appears fairly adaptable. Seems like it would be a great addon allowing easy expansion of memory perhaps.
