Beginner here. I am working on a project using a Sure amplifier and noticed there is a ground label on one of the holes used for mounting. Do I need to do anything special for this? The link below shows the pcb and the bottom right mount hole with the ground symbol.
(Source)
  • \$\begingroup\$ I would wait for someone to confirm, but it may mean that you can/must connect it to the enclosure (assuming you are putting it into a metallic one) to have it at 0V. \$\endgroup\$ – Serge Jan 2 '13 at 2:21
I'm assuming that this is the 2 x 15W amplifier. If so, the Notice section details the proper use of the GND terminal:
GND should be connected to GND or the housing of your instrument.
| improve this answer | |
