12
Too often we get / give the advice to replace all electrolytic capacitors on a PCB when it starts to malfunction (like in DVD player power supply circuit strange behavior. Need help to understand root cause but here are many more examples). Reason seems to be the huge difference in quality for these capacitors. And more often than not, replacing caps actually solves the problem.
Now it occurred to me that some devices just appear to live forever (knock on wood), where others fail in two or three years. With new brands coming and old brands going, compiling a list of good/bad brands is a hopeless exercise, so the question is:
How do I know a decent/good quality electrolytic capacitors, before I buy them?
Let's assume:
  • I know the brand (by calling/mailing the shop);
  • The parts are genuine, non-counterfeits;
  • Fresh parts; short shelf life (no expired "best before" date)
  • 5
    \$\begingroup\$ You have to know the manufacturer and know that the particular product line has a good history. Then you have to trust the supplier that they are in fact delivering product of the stated brand, not counterfeits. \$\endgroup\$ Commented Jan 1, 2013 at 21:25
  • \$\begingroup\$ @OlinLathrop Sounds like an (the) answer to me. \$\endgroup\$
    – m.Alin
    Commented Jan 1, 2013 at 21:30
  • \$\begingroup\$ Say I call the shop, they tell me the brand name and they do sell me non-counterfeits. How can I figure out if the brand is any good or not. \$\endgroup\$
    – jippie
    Commented Jan 1, 2013 at 21:36
  • \$\begingroup\$ I don't want to believe that compiling a white list / black list is the only option. I mean, we must be smarter than that ;o) \$\endgroup\$
    – jippie
    Commented Jan 1, 2013 at 21:37
    \$\begingroup\$ @jippie: You need to know that the shop is legit. Many manufacturers now communicate this information of who is a legit distributor on their website to avoid this sort of issue. There is some kind of association dedicated to eliminating counterfits. Aside from all this, if the deal is too good to be true, it probably is. \$\endgroup\$ Commented Jan 1, 2013 at 21:37
This is a challenging question to answer. The best answer I can give is "caveat emptor".
You first need to know that the brand is reputable. My experience leads me to implicitly trust these brands: Nichicon, United/Nippon Chemi-con, Rubycon, Panasonic and Samxon. Major manufacturers should be able to provide life test data to justify the hours-of-life ratings that are on the parts.
You also need to know that the application isn't over-stressing the capacitor. A bad design that leads to excess ripple current or operating temperature or excessive voltage (or some combination of the three) may cause even the best capacitors on the market to fail prematurely. Using a general-purpose capacitor in a circuit that needs a high ripple, low-impedance capacitor is a prime example of where things can go bad quickly. A good cap in a circuit with good design margins should last years without issues, as the design will accept some degradation of the capacitor over time before failing.
Only when you know these two factors would you even be in a position to judge why a capacitor failure occurred.
You need to trust your supplier. The caps need to be stored in proper conditions with date-of-manufacture to determine if any forming/healing needs to be performed on them before sending your circuit out into the world - ideally, the caps should be new enough that this isn't an issue, but sometimes you need a certain value and you have to make do with whatever you can get.
Counterfeit parts are a huge problem and even a reputable shop (or international distributor) can occasionally be fooled, especially with 'lean' warehousing and part inventories moving from place to place.
  • \$\begingroup\$ I used to buy Philips and ITT, but to my knowledge they don't produce these parts any more. What I am trying to say is that brand names change and I am bad at tracking takeovers. \$\endgroup\$
    – jippie
    Commented Jan 1, 2013 at 22:35
  • \$\begingroup\$ So you are basically saying: check if the manufacturer's website for detailed datasheets and if they are unavailable don't buy them. \$\endgroup\$
    – jippie
  • \$\begingroup\$ Thnx for the design concerns/shelf life considerations, good points. I doubt counterfeit is easy enough to solve in a simple question like this. \$\endgroup\$
    – jippie
    Commented Jan 1, 2013 at 22:36
    \$\begingroup\$ +1 - nice answer. It amazes me how many otherwise well designed products fail to pay enough attention to power supply capacitors. You see dodgy brands, not specced for switching supplies, borderline voltage ratings, not glued down properly, placed right next to hot components, etc, etc. Even with attention to detail, they are often still the most likely source of failure. I don't mind too much, though - I'v e nabbed plenty of easily fixed cheap deals in my time due to this fact ;-) A good LCR/ESR meter is an essential tool for any lab. \$\endgroup\$
    – Oli Glaser
    Commented Jan 2, 2013 at 10:03
    \$\begingroup\$ I recently watched a blog on a teardown/repair where this was a problem, here it is. \$\endgroup\$
    – Oli Glaser
    Commented Jan 2, 2013 at 17:25
