-1
A Colpitts oscillator makes use of the common emitter configuration, and the indicated amplifier configuration is known to be a linear circuit. How come do we call the stated oscillator a nonlinear circuit? How would removal of the emitter bypass capacitor in the common emitter configuration hurt the whole oscillator?
    \$\begingroup\$ A colpitts oscillator can be common-emitter, common-collector or common-base. I think you need to post a picture of what you are talking about especially the bit about the emitter capacitor. \$\endgroup\$
    Oct 13, 2020 at 7:44
  • \$\begingroup\$ How would removal of the emitter bypass capacitor... Think, what does the capacitor "bypass", DC signals and/or AC signals? Low/high frequencies? How does a common emitter amplifier with a bypass capacitor behave (what gain, bandwidth etc..) and how would it behave if that capacitor was removed? A Colpitts oscillator makes use of the common emitter configuration I can design a Colpitts oscillator without using any common emitter circuit! \$\endgroup\$ Oct 13, 2020 at 7:51
  • \$\begingroup\$ Maybe this link might help you understand what you want? \$\endgroup\$
    Oct 13, 2020 at 8:45
Question: "How come do we call the stated oscillator a nonlinear circuit?"
Each oscillator is and must be - per definition - a non-linear circuit. This is because for a safe start of oscillation the closed-loop pole pair must be in the right half of the s-plane (loop gain >1). As a consequence, the oscillation amplitudes continuously are growing until a non-linear effect within the feedback loop reduces the loop gain to unity.
(In reality and due to some delay in the feedback loop, the loop gain will slightly "swing" around the nominal value of "1" - and the pole pair will move slightly between the left and the right half of the s-plane).
This non-linear effect can be caused (a) by a simple limiting effect (fixed supply voltages) or (b) by a non-linear gain characteristics of the amplifier.
