I have a PCB where I placed a 100uF capacitor near the power supply connector, for power filtering. This capacitor is too big so in my next design I want to use two 22uF capacitors.
My question is: should I place them near each other and near the power connector, or place one of them near the power connector and the other one on the oposite side of the PCB, for uniform voltage stabilization?
The PBC is 80mm x 50mm and the power supply connector is near the 50mm left edge.
EDIT: this circuit is a 24V to 3.3V signal converter only using resistors and transistors, no uControllers or ICs. The signals are square waves with max 50Hz.
